Has anyone done a clutch cover modification to get at the clutch free play adjustment. I have seen a few guys with holes behind their clutch cover insert, but have no idea what they are sealing it with. If anyone has come up with something please let me know and throw up pictures if you have any. At the very least I could use an idea for something to stick in the hole after I make it. I have thought of cutting an o-ring groove in the back of my cover insert, but I'm not sure that's the best idea.
:cheers:
once you get that set why would you need to adjust it? when we adjust ours we do it with the clutch cover off and the clutch cable and everything hooked up. why would you need to adjust it later?? im just curious :confused:
338170[/snapback]
I agree... Why?
I have done this to many Banshee's, why remove the cover just to make an adjustment?
I used a boring bar in a vertical mill, but a 2 1/2" holesaw works good too. /
338259[/snapback]
What seals this?Do you just use the stock piece of rubber between the cover and the insert?
i know a guy that cut a hole in his also but not 2.5 inch more like 1.5.
he used some rtv or silicone to make a gasket around the cover. kinda po dunk but it works
338170[/snapback]
Some asshole (me) didn't do a good enough job of roughly adjusting it before the enigine was put in the frame and buttoned up the side cover. Basically I am looking for a shortcut that doesn't involve purchasing a Direct Drive or Hinson side cover setup, nor am I motivated enough do the make a similair set up myself.
:blink:
Additionally, I trying to do this as correctly as possible, given what I want to do. Therefore, "po dunk" or things that require RTV are not what I am shooting for here. All of this is purely spawned from laziness and cheapness. I really don't want to pull the stock cover off and I really don't want to buy a new cover as my biggest hang up with that is actually still pulling the cover off. I could also pull the cover off and go toss it in the HAAS and do basically what Hinson charges $700000 for, but still, I'm lazy.
It seems to me that I saw a reputable builder (maybe it was Twister) was doing this modification with some sort of rubber plug that was roughly about 1" in diameter. I just want to know where to get a grooved rubber plug that has a groove thick enough to fit the case but not protrude into the clutch hub. I ran out of ideas for the plug yesterday, now I am frantically searching the internet for the picture of this modification that was not slutty, that I swear I saw.
:shrugani:
to each their own
what bdbanshee did, costs nothing. yeah some silicone isnt the best solution but it would work. take your time you probably wouldnt ever know that you didnt it. if you did a good job.
tube of silicone is like 4 bucks.
but if you get it adjusted right the first time shouldnt have to adjust it a bunch
to each their own
338455[/snapback]
I agree that if I did it right the first time, then I wouldn't have to adjust it a bunch, but I'm retarded.
Right now I am trying to decide if I want to cut an o-ring groove in the insert cover or wander around town trying to fing a rubber plug that would work. If anyone has ideas for a plug I can still use them.
Also, if anyone has any recommendations for who to go through to get a lock-up cover and clutch plate, speak up. I can't decide between Direct Drive, Matoon Machine, and Southern Style Racing. This is probably what I will go with in the end.
:headbang:
most bikes shouldnt need a lock up unless you are making serious hp
if i remember right, use some r6 or whatever bike fibers, stock steel, and i think they said toomey springs is good to 100+ hp
dont quote me on it but i saw something like that on planetsand.com
That clucth cover looks cool .Who does that mod.
338366[/snapback]
direct drive,
southern style just had a killer deal on direct drive lock ups and new polished covers so you should email Buddy.
http://www.southernstyleracing.com/
after putting the lock up on I couldn't believe how much my clutch was actually slipping. I had 6 toomey springs in there too. The way the clutch is designed they all will slip, some more than others. I had new fibers and plates with 6 toomey springs. It grabbed awesome, I thought. Then I put the lock up on and now it really grabs!!!! The lock up really helps on good traction terrain. I ride on the street alot and can tell a big difference. I should of done this a long time ago.
Edited by 1800bigk
