blaster250 Posted March 2, 2005 Report Posted March 2, 2005 hi guys i was wondering if i could port my new piston to my cylinder,has anybody done this before and what can i expect from this. any help would be appriciated, thanks in advance. Quote
scotts96fast Posted March 2, 2005 Report Posted March 2, 2005 hi guys i was wondering if i could port my new piston to my cylinder,has anybody done this before and what can i expect from this. any help would be appriciated, thanks in advance. 331936[/snapback] Yup done that for two years.I did notice a difference,BUT I broke two piston skirts in two years....I've been running the same brand pistons now for 3 years.This winter I just put new rings in and a hone.....It's not worth it in my book. Quote
PassionRE Posted March 2, 2005 Report Posted March 2, 2005 BUT I broke two piston skirts in two years.... Yep....thats what you can expect from that mod....Jim Quote
pimp559 Posted March 2, 2005 Report Posted March 2, 2005 Are you guys referring to opening the window on the piston or cutting some off the bottom of the skirt? Quote
blaster250 Posted March 2, 2005 Author Report Posted March 2, 2005 (edited) Are you guys referring to opening the window on the piston or cutting some off the bottom of the skirt? 331954[/snapback] opening the window to match cylinder Edited March 2, 2005 by blaster250 Quote
stclark816 Posted March 2, 2005 Report Posted March 2, 2005 I know of some people that have done it.. They didnt notice a whole lot. It's a good way to weaken the piston and cause problems. It's really not worth it. Quote
RBD Posted March 2, 2005 Report Posted March 2, 2005 Yes I do Banshee pistons all the time and it works good. I would only recommend doing it to Wiseco pistons. Quote
badcompany Posted March 2, 2005 Report Posted March 2, 2005 My builder does it, ran about 8 months and we tore down, looked good as new. I cant say how big a difference it makes, because he ported them when he ported the cylinders, but i will say that the bike runs decent Quote
bogart Posted March 2, 2005 Report Posted March 2, 2005 Yes I do Banshee pistons all the time and it works good. I would only recommend doing it to Wiseco pistons. 331975[/snapback] ive seen it done alot.i did it to a old 80 a freind had.the bike had no powwer in the first place but i didint really notice anything but in a shee maybi Quote
RBD Posted March 2, 2005 Report Posted March 2, 2005 ive seen it done alot.i did it to a old 80 a freind had.the bike had no powwer in the first place but i didint really notice anything but in a shee maybi 332177[/snapback] Piston porting will work with other mods, like head work, pipes higher flow air filters and cylinder porting. You will not notice much with a bone stock set up bike. The ported pistons help the flow through an engine, but first you have to have a good way to get the flow in and then out again. Ron Quote
2stroke_addict Posted March 3, 2005 Report Posted March 3, 2005 vito's SS forged come already ported, avoid the hassle and get a pair. Quote
bogart Posted March 4, 2005 Report Posted March 4, 2005 Piston porting will work with other mods, like head work, pipes higher flow air filters and cylinder porting. You will not notice much with a bone stock set up bike. The ported pistons help the flow through an engine, but first you have to have a good way to get the flow in and then out again. Ron 332274[/snapback] oh of course you need mods to support other mods.it was already ported some so i opened the window.the bike is slow as shit anyways. Quote
RBD Posted March 4, 2005 Report Posted March 4, 2005 How fast do you think an "Old 80" should be? Quote
rocketboy Posted March 4, 2005 Report Posted March 4, 2005 ive done this mod for several rebuilds on my she now with wiseco prolites, but i only raise the windows .100 and dont widen them,the cracking happens because when you machine hard brittle materials (froged pistons)you introduce stress into them and tiny cracks not visiable to the naked eye , its a good place to start a bad crack and if it breaks it will usually shatter from edges of the intake window. depending on how you machine the piston will depend on its reliability over time ,i only do it to start the intake charge sooner on my bike ,but its not much a performance gain just a tad faster revs at low speeds ,i wouldnt widen it either , the transfers and intakes in your jugs do alot more than the piston does to draw in air/fuel mixture ,i think its worth doing(raising window.100) but not as a replacement for good port and polish work Quote
blaster250 Posted March 5, 2005 Author Report Posted March 5, 2005 thanks alot for the info guys,i took alittle off the top window just to be safe. thanks for the help Quote
