quick-z Posted February 26, 2005 Report Share Posted February 26, 2005 IF I PUT ON A 13 TOOTH FRONT SPROCKET CAN I USE THE SAME CHAIN Quote Link to comment Share on other sites More sharing options...
blaster250 Posted February 26, 2005 Report Share Posted February 26, 2005 IF I PUT ON A 13 TOOTH FRONT SPROCKET CAN I USE THE SAME CHAIN 329917[/snapback] SURE YOU COULD YOU JUST HAVE TO ADJUST THE CHAIN,BUT ITS BETTER TO CHANGE BOTH SPROCKETS AND CHAIN AT THE SAME TIME. IT DEPENDS ON HOW WORN THE OLD ONES ARE,IF NOT TO BAD YOU WILL BE FINE. Quote Link to comment Share on other sites More sharing options...
cam2 Posted February 26, 2005 Report Share Posted February 26, 2005 SURE YOU COULD YOU JUST HAVE TO ADJUST THE CHAIN,BUT ITS BETTER TO CHANGE BOTH SPROCKETS AND CHAIN AT THE SAME TIME. IT DEPENDS ON HOW WORN THE OLD ONES ARE,IF NOT TO BAD YOU WILL BE FINE. 329933[/snapback] i agree. i've swapped front and rear sprockets experimenting with different combos while using the same chain which is in like new condition and i haven't had any problems. if you have a chain that is worn then it will probably cause your new sprocket to wear immaturely. i know that it's recommended to change every thing as a set but if you're just swapping sprockets for a short period of time to experiment and then buy a new chain and rear sprocket when you find the gearing that you like then you'll be fine. Quote Link to comment Share on other sites More sharing options...
Cotton eyed Joe Posted February 26, 2005 Report Share Posted February 26, 2005 IF I PUT ON A 13 TOOTH FRONT SPROCKET CAN I USE THE SAME CHAIN 329917[/snapback] Depeding on how long I ran the chain, I've almost always changed front and rear sprockets and the chain at the same time. If its just a quick sprocket change in size or something, if the chain fits I still use it. Quote Link to comment Share on other sites More sharing options...
