Theres a plce around here that charges 80 bucks for it, im putting my completly redone banshee back together and i was thinkin if it would make numbers that would be worth the 80 bucks, its stock stroke but its got 20cc domes, v force reeds, 30mm carbs, all around port work, wiesco .70 over pistons, fmf fattys with toomy t-3 silencers, and not sure if they add hp but its got reed spacers and a nice grab bar rated for a few extra ponys, i no i cant get exact numbers without spendin the 80 bucks but you think the hp numbers would be worth the money?? Thanx for any input
if nothing else you could dial in your jetting with a dyno run.....80 bucks isnt bad, they're charging 100 bucks here...
its worth it if you wanna see how much power you are making. might as well tune it some and get it running better. heres its about 100 bucks an hour to tune. theyll cut you a break if you are there for a while. most places ive gone to if you wanna rent for a whole day its about 400 bucks.
Should be around 50-53 depending. That's about what I made before porting.
Dyno jetting IMHO is always too rich for the real world. The dyno is a load that you quad never sees in real life. I have always had to jet back down after dyno runs.
But if you want to spend the money, do so. I did it, just to do it, and I don't regret it. It was just to get the chart.
Besides, I got the guys at Trinity to say that my bike ran damn well for not being ported. :)
One bit of advice, don't bother doing a dyno run just trying to get some good #'s unless the shop has dyno tires for you to run (slicks that are very solid) or you will get lower #'s and the dyno drum will eat your knobs for breakfast. My experience using the dyno sniffer for A/F ratio to determine if any jetting changes were necessary was that the sniffer A/F reading was right on the money and accurate for jetting changes both on the dyno and regular riding. My local dyno (not at a dealership) charges $50 for a #'s only session and $75 for a dyno tune and #'s session. If they are doing more bikes than just yours then they don't charge any more for additional runs that day to check A/F after jetting changes.
