Bansheeman1121
Everything posted by Bansheeman1121
  1. Interested in the bottom end and 1 piece intake still got?
  2. Broke mine loose with my 1 inch impact. Whats the biggest gun you got?
  3. Can anyone else weigh in bearings seem real tight
  4. The bike should still run and idle without the splash guards . Have you checked your pilot jets? Played witht he idle screw at all? Was it happening before you took the carbs apart or after? The choke tube runs on the inside of each carb and they can very well be your problem make sure it run inbetwenn the carbs
  5. What dod the plugs look like after a run? Leaning out maybe it sucking air.. Black fuel soaked maybe your sparks getting weak when hot. How do they look
  6. Does one of those bushings for the rear shock itsself or just the linkage that hold the sock to the swingarm? Ill probably that this off your hands
  7. Im getting my banshee back together after 3 years and noticed the rear carier has alot of side to side play in beetween the sprocket and rotor. The bearings are pretty new and theres no up and down play in it. The axle nuts are tight as they will go. This is a dura blue axle if it matters.. Stumped whats worn out!?
  8. Price on the a arms? What kind of shape are they in?
  9. Good new springs vitos needles new gaskets and good throttle cable. Only problem ive had is the one little peice always falls out i forget what it is ill look at em and let ya know tho its on the outside of the carb it just goes in like the throttle screw but its not threaded in?
  10. Im lookin into fullflight a arms on ebay... Not sure what kind of quality they are. Also what is better to run for me. I ride alot of open areas coal hills and open roads +3+1 or+2+1? Not to sure whats better for what type of riding! Thanx for some help
  11. 150 shipped is ok depending on your location where are you at?
  12. hah i ran them a arms for 2 years powdercoated any balljoints will wear out and same for bushings.. Exept banshees with walking beam suspension under em they tend to be severe duty.. I will get pics asap than
  13. Probably when I " race cut" my back plastics. I hacked em up so bad i ended runnin without em til i could afford new ones.. Or some of my young days running my cold air intake consisting of a shop vac hose with a gatorade bottle on the end to scoop up the air.. Another good one on my buddies car we tryed running the windsheild fluid hose into the carb and filling it with octane booster homemade nos lol none of em worked out so well...
  14. I got some stock A arms powder coated black with aluminum skid plates will sell them with tie rods and ends... 65.00 Stock Carbs with tors removed and good throttle cable.... 60.00 FmF FATTY pipes and silencers chrome is somehwat rusting.. Neg make offer.. Stock cdi box came off my shee running.. best offer I can get pics of anything if needed via text or email. Thanx for looking
  15. 80 for the set? There powder coated black with a bit of silver in it not sure what you would call the color. I am about 1 1/2 hour north tords scranton
  16. comon guys i will practicly give this stuff away!! Stock A arms with skids under em, almost new tie rods with good ends stock cdi box stock swinger stock carbs w tors gone with new throttle cable fmf ssts the chrome is a bit worn maybe they can be polished? 570 241 2236 if interested Thanx!
  17. Sry i havnt got back to you guys the skid and grab bar are gone but I got a hyrdolic clutch with it if your interested
  18. Forgot to mention for the plow im in ne PA so I guess its best sold to someone local
  19. Im parting my 99 banshee Lots of stock and aftermarket parts for sale. I also have the plow f/s i used it on my honda foreman works great. Plz contact me at 570 241 2236 if you need any parts i am not able to get on my computer to much. Thanx
  20. Call me at 570 241 2236 if interested
