I have just had my bike upgraded with new wiseco pistions, port work, lightned flywheel, and reeds, my stock clutch is slipping in the upper gears and I was wanting to replace it. I have heard that tusk makes a good clutch but wanted some different opinions on what I should get. Also do you think I would benefit form some 34mm carbs, I have read some post that recemend 33's or 35's but why not 34's am I missing something?
Kehin carbs:
33mm and 35mm are both Kehin's newer style carb (PWK) thats why there is more talk about them.
34mm is Kehin's older style carb (PJ). Don't be afraid to get a PJ, they are still good carbs. Honda used them from the 1980's all the way up till 1997 on the CR 250's ,125's, and 500's (01')
Kehin carbs:
328626[/snapback]
you think you know soooo much... :P get your shit running yet?
sure will super, just order the right cable from motion pro to match up to the carbs n u'll be good. i'm doing the same . i got 1 PJ so far so i need 1 more carb plus the cable to do it. i'd be done by now but my banshee suddenly stopped running. i have no spark! i wish someone could help me out. good luck witrh the carbs tho
tusk clutches kick ass i run one on my she and its much improved over stock ,the plates are perforated and fibers are much beefier than stock, well worth the money ,get ebc springs for like 6$ too and run 3 stock 3 ebc and youll be rippin ,its about the best deal from rmatv you can get ,i love mine.as far as the carb dilemma ,id be looking at the 33 pwk they are d slides pj are not dslide carbs .the d slide design offers the best all around reponse on modified motors from what ive heard. :cheers:
