banshdog Posted February 17, 2005 Report Posted February 17, 2005 I'm looking to get a case saver that will fit around a 15 tooth front sprocket. Anyone with a 15+ tooth front have a case saver? what brand? Quote
PUSH THE THROTTLE Posted February 17, 2005 Report Posted February 17, 2005 I thought they all fit a 15t. Oh well I'll be machining mine I guess. Quote
RNBRAD Posted February 17, 2005 Report Posted February 17, 2005 I've always been curious as to the aluminum compared to the poly plastic units. I'm afraid energy may transfer through the aluminum unit where the poly unit would absorb the impact better. Anyone have any thought or idea's on this, or even thought about it? Quote
1800bigk Posted February 17, 2005 Report Posted February 17, 2005 I just bought this one and it fits 15 no prob and I shaved a little bit and it fits my 16 now too. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW Quote
PUSH THE THROTTLE Posted February 17, 2005 Report Posted February 17, 2005 I've always been curious as to the aluminum compared to the poly plastic units. I'm afraid energy may transfer through the aluminum unit where the poly unit would absorb the impact better. Anyone have any thought or idea's on this, or even thought about it? 325167[/snapback] Possible, but my understanding was that the case saver is supposed to keep the chain from Quote
BrianEb Posted February 17, 2005 Report Posted February 17, 2005 I got mine from TM DesignWorks its the poly type Quote
ledofthezep Posted February 17, 2005 Report Posted February 17, 2005 I got mine from a guy on here, went by the name of 'csaver' I believe. It's the poly type too. It was under $25 shipped I know that...no problems and/or complaints either. Haven't seen or heard of the guy in some time though. Quote
bigboybanshee Posted February 17, 2005 Report Posted February 17, 2005 I got mine from a guy on here, went by the name of 'csaver' I believe. Quote
MILO Posted February 17, 2005 Report Posted February 17, 2005 (edited) how much trouble has anyone actually had with the chain breaking? if your chain is maintained and not excesively tight, it shouldn't snap, right? i suppose getting some amazing air and really slamming the landing might do it. if it's just worn out that bad, well, i don't let mine get worn out that bad. i understand that $20 or so compared to a cracked case is well worth it. but how often has it happened?? i'm just curious because i've never had a chain snap on anything in about 18 years of riding. Edited February 17, 2005 by MILO Quote
PUSH THE THROTTLE Posted February 17, 2005 Report Posted February 17, 2005 I shifted to powerslide around a corner on gravel once and that Quote
1800bigk Posted February 17, 2005 Report Posted February 17, 2005 The only chains that have snapped on me in the past have been aftermarket chains with a clip type master link. The place that broke was the master link, I guess it has to do with the clip thing. If you have a D.I.D chain look at the instructions, it says "D.I.D. strongly recommends you to use a rivet type master link even when the clip type is available." Rrivet type is the endless chain, like a stock chain. Quote
ledofthezep Posted February 17, 2005 Report Posted February 17, 2005 If it's the same guy I got mine from his name is c_rossman (Chris Rossman, the same guy in the ebay link that 1800bigk posted) I bought mine from him through ebay for like 20 bucks. I'm running a 15 tooth right now and it required no modifications. Great service and product! 325206[/snapback] That would be affirmative. I highly recommend the guy as well. Quote
