I recently bought a banshee off the internet. I bought it not running. It has all the essentials. I cleaned out the carb. It has a new top end, and good compression. If I take out the plugs and put a few drops of gas in there it fires and dies. Any ideas on what to look for, or any more specific details?
sounds like a fuel issue to me. u said u got good compression and with some extra gas it does fire.. so theres spark and compression, 2/3 of the process.Check the plugs, should be a chocolately color. are there any mods done? ill bet its the jetting if there is. 2 stokes are finicky little bitches, a seemingly insignifigant change in temp altitude even humidity will make it "not right".u might have inherited someone elses problem.try to get in contact with the seller, ask what he did or tried, no sense in going down the same road he did. for the cheap cost of jets u might wanna play with that first .try going up a size or 2.
It does sound like a gas problem. Did it have gas in it when you bought it? Were the carbs dirty when you cleaned them? Did you check the main fuel line? Make sure you clean the hell out of the carbs> take the main and pilot jets out, go to town with the carb cleaner! Make sure it has fresh gas and the lines arent gummed up. Mabye throw in some new plugs too.
