ok
i'm a little dumb here ...
2001 stock motor stock reeds
FMF Fattys with power core silencers
K&N air filter w/outwares
lid on with no holes no snorkle
in connecticut.......215 above sea level
Thanks for the help on were to start????
Edited by beatmiester
Take air box lid off:
Go with 280-300 mains leave everything else stock, Except on the air screws, they should be like 1 1/2 turns from seated. The colder the temps, the bigger you may need to go on the mains. :cheers:
Note: hold the airfilter assembly with a screw.
Do not want to take off the arbox lid then:
Go with 260 mains... air screws 2 1/4 turns out from seated.
Edited by richybanshee
When I ran stock carbs and Fattys, I couldn't seem to get the needle rich enough, even with the clip all the way down. I bought the Dyno Jet jet kit. The bike ran awsome after that, It was jetted perfect all the way through. I would highly recomend going with the Dyno Jets. The kit comes with two or three different mains, and different needles.
I did use Alba jet needles, they work and cost like $15 + shipping. Vito's needles are another alternative.
If you allready have a lot of main jets and pilot jets, just by the jet needle. The needle is longer and thiner than stock.
I dunno about 280 I have same mods but with a cut lid and at 1,000ft. I run 330 and 4th notch on the needle. I would think that anything below 300 in conn at this time of year would be lean. But the only way to tell is a plug chop. Leave the guessing to weight guessers at the fair. JMO :confused:
270 mains, needle 4th clip from the blunt end, stock pilot, adjust air screws to throttle response. If you want a little more,then cut the last 1.5" off the end of the lid right behind the clips...that'll give you another 2-4hp..
  • 4 weeks later...
ok
i got my pipes back from being rechromed they do look nice and i'm ready to go
i got a K&n with a plate
so now i will go with no air box lid
FMF Fatty and power core silincers
K&N w/outerware no lid
stock carbs w/tors stock jetting
where do i go a jet kit with neddles or just use stock needles and buy main jets and pilots
i'm in connecticut and i'm looking at running it from 50-90 degrees
thanks for the help
