Otis Posted February 9, 2005 Report Posted February 9, 2005 I need to replace my rollers. Need some input on what to get, and what to stay away from. Any advantage to using the slider over the roller? Quote
ledofthezep Posted February 9, 2005 Report Posted February 9, 2005 Well I use both. I use rollers where there needs to be rollers, but on the swingarm I use a slider instead of that stock shit wheel that wears faster than an lubeless condom in a dry-rot pussy... T.M. Designworks - lifetime warranty & works great. Quote
PUSH THE THROTTLE Posted February 9, 2005 Report Posted February 9, 2005 I use a slider instead of that stock shit wheel that wears faster than an lubeless condom in a dry-rot pussy... 320291[/snapback] LMFAO Quote
MILO Posted February 10, 2005 Report Posted February 10, 2005 i have the upp racing slider/roller kit for about a year or more now. working great so far. initial assembly takes a little work, but it's well worth it over the stock style. Quote
banshee tuner Posted February 10, 2005 Report Posted February 10, 2005 The tm designworks have a one year warranty and that is what I got out of them. For the price I was not pleased. Now I run a roller that I got from a place I worked and is is a trolley wheel for an overhead conveyor. It works the best for me and it was free. Quote
dnhyoung Posted February 12, 2005 Report Posted February 12, 2005 (edited) I highly recommend geting the Upp racing set-up. Have had them for over a year, and love them www.uppracing.com Edited February 12, 2005 by dnhyoung Quote
Cotton eyed Joe Posted February 12, 2005 Report Posted February 12, 2005 I'd go with a slider due to the increased surface area over the chain. It will reduce the amount of wear that you would normally see on a roller that makes contact over about 10 degrees versus laying nearly flat on a slider. I made a couple of rollers out of Nylon last year because Nylon is some tough shit. 1 trip is all it lasted. I came home from Dumont with about 1/4" or less of roller protecting my swingarm. If it were a slider, you probably wouldn't even think I had ever used it other than the huge fucking grin I had on my face for the next 4 months. Quote
RNBRAD Posted February 12, 2005 Report Posted February 12, 2005 Problem is the roller is a pos because it don't roll. Slider is the only way to go. Quote
dnhyoung Posted February 12, 2005 Report Posted February 12, 2005 uess that I should of clarified, the UPP set-up has a slider for the swingarm, and rollers for the upper and lower chain guides with sealed bearings. Quote
