Will a boost bottle really make a difference on my shee or is it just money down the :flush: ? I have an 2005 Alba Banshee with T5's, dyno jet, and K&N, my bike runs great But I would like to go faster... Just worndering what you all think
I have a boost bottle. It resides in a rubbermaid container in the garage. I made slugs that I plugged the holes with. I tested the boost bottle, stock balance tube, and the plugs. I like the performance of the plugs. Seems that the throttle response is right the way I want it with the plugs....
Boost bottle seems to help slightly if your all stock but no help at all with mods. I went back to the balance pipe. Tried plugging the holes and seemed to take away slightly. If you know someone with one try it and see, hell I'll sell you mine.
i think trinity or somebody has a intake kit where they don't even have a spot for the boost bottle/balance tube... and i know jimsandtoys in oklahoma plugs his with plugs... so i think it almost be better to block it off but would depend on what is done to your engine....
Boost Bottle....lots of pain, no gain. I agree that there are other mods you can look at that will give you what your looking for. Stay balanced on the tube, you should be fine.
I have a boost bottle on mine only because it came with the intake setup I have. I felt a difference because I did the intakes and V-force reeds at the same time, but I do not think the bottle itself makes a seat in the pants difference. Mainly for looks. Some advice for you duners running the bottle, take the boost bottle grommets off and coat the grommets with silicone and re-install it. Something I do so I do not get sand in the motor.
Ken
