i am planning a run at local track in nj . i got the following. big bore 409 cc cylinders, 21cc cool head, v froce reed cages, tors removal(not that it matters)jet kit, kandn filter, 15 ft sprocket 41 rear sprocket,toomey t5's pipes and silncers
f70da39b.jpg those are the front tires i am going to be running
Edited by blaster105
no you can run either, e town has a quarter and an 8 th. 15 or slower i would imagine.atco has a quarter. you can shut down at the 8th.
  • 2 weeks later...
  • 2 weeks later...
  • 2 weeks later...
hey if you are looking for tires try here. [url=https://secure5.nexternal.com/shared/StoreFront/default.asp?CS=nacs&BusType=BtoC&Count1=567959010&Count2=485099434&ProductID=629&Target=products.asp
yea that last post the link doesn't work but go to nacs racing. thats were i got my tires. also if you lower your quad you get a better start. i put struts in mine. made them out of round tube. lowered to like 3 1/2 of the ground in the front.
  • 2 weeks later...
Flat track tires work great ang you can get some used ones off Ebay for cheap.
311421[/snapback]
i think should be in the high 14's in the 1/4 with all those mods. but i would go with a 14 sprocket in the front
293736[/snapback]
How goos is them 409 cylinders
