BLACKBANSHEE04
Everything posted by BLACKBANSHEE04
  1. I heard that no jets come with the cpi pipes so what will be the best jet to run with a ported cylinder running pump gas
  2. Does anybody know where in south carolina i can get my cylinders ported
  3. If anybody on this forum is from south carolina i would like to know is there anywhere i can get my cylinders ported
  4. Can somebody tell once again what is the best top end pipes cpi high rev pipes or the toomey 5 an maybe procirut
  5. Why do alot of people cut their fenders
  6. Can somebody tell do i have to cut my front fenders in order to use the cpi inframe pipes
  7. Is a sand dune drag port is made for only sand because i ride and race my banshee on the back roads
  8. What is the size of a 68mm piston because i heard that banshees tend to overheat when u bore .80 over
  9. My banshee is stock but i got plans because i want to dog a raptor and a ds650 but my first plans for my banshee is 1. buy some ported cylinders 2. pipes 3. bore 20 over 4. vitos super stock pistons 5. 15 teeth front sprocket 6. timing advance 7. better water pump 8. vforce reeds 9. head with mayber 20 or 21cc size domes for pump gas And my second plans is 1.4mm long rod stroker crank 2. bigger carbs 3. better radiator
  10. What kind of work does it take to fit a 7mm stroker crank in a banshee and i heard something about the crankcase have to work and i'm just wondering can a local yamaha dealership do the work
  11. Which pipes will give better top end with ported clyinders and i was wondering should i get cpi high rev or toomey 5 racing pipes. THANKS
  12. What i was trying to figure out that i seen a 4mm long and short rod stroker crank and i seen some pistons by vitos for the standard length rod that will give u 8hp mid to top and then if i use long rods will the wiesco long pistons give me any power like the superstock stock piston from vitos
  13. Which rod will give the most power with ported cylinders short or long rod
  14. I'm trying to look for the best reeds to buy that will give more horsepower then stock
  15. Who sells the ricky stator ignition
  16. Could i run pump gas with 20cc domes i don't know the elevation in south carolina but on the other hand which crank will give me more power a short or long rod and who sells the cheapest stroker cranks
  17. Also what is the difference between a short and long rod, and what is wrong with vitos pistons
  18. A 15/41 gearing shouldn't be no problem with what i have listed because really i'm just trying to get faster than my cousin stock raptor
  19. Its just the money i have but will 15 or 16 on top will help speed with a little engine work
  20. I would like to know what is the best gearing for high speeds like 90+, but my shee is stock but i'm gonna do some work to it and maybe that will give some hints 1.toomey 5 pipes 2.v force reeds 3.4mm stroker crank with standard size rod 5.+4 timing key 6.racing head with 20cc domes on pump gas 7.cdi rev box that will allow u to rev a extra 1000 rpms 8.high flow water impeller 9.vitos superstock pistons .20
  21. Can somebody tell me which pipe will give more top end
  22. What is the stock size domes in the stock head
  23. Is the vforce 3 reeds better than the old ones
  24. I know where a dual exhaust kit for the 450 at
