hey everyone new here< just curious what you guys think? already have toomey t-5's boost bottle(useless?), mild port/polish and shaved head, race pistons, any ideas would be appreciated, anyone know anything about trinity's 421cc kit??? how much and is it worth it thanks ....... Can't wait for ice :cheers:
advance your timing, get a bigger set of carbs, and some aftermarket reeds, all should fit in that budget
291449[/snapback]
word. v force reed cages perhaps. maybe a set of 28 or 30mm kehins. and you can get a timing plate for next to nothing usually. try ebay.
Go with VForce reed cage aprox. $220 aprox. HP gain 2
Get a Timing Plate ($100 aprox) and advance it to +3 if running pump gas (also depending on compression)
remember that if you have a lot of compression and advance the timing Too much your engine will run hotter and piston failure will be possible.
Edited by richybanshee
If it's fast enough get some shocks.
You can get an adjustable timing plate from ricky stator for $35.
What type of riding?
Edited by fixitrod
thanks for all your input guys i appreciate it looks like the advance timing is pretty popular i'll go that route and lighten the flywheel, how exactly do you lighten the fly wheel?? sorry probably a newbie question... thanks again
To lighten your flywheel you have to shave it the inside I think because if you did it on the outside it would screw with the pick-up right?? i dunno pm boonman about your flywheel he seems to be the guy who knows about them on here.
hope you like your new mods
:cheers:
