WHEN THE BIKE GETS WARM IT STARTS BURNING COOLANT LIKE A MOTHER AND IF SLOW DOWN WHILE UR RIDING AND SIT AND IDLE U COULD SMOKE OUT 2 ACRES I REPLACED THE O-RINGS IN THE COOLHEAD THINKING IT WAS THAT AND IT'S STILL BURNING IT AND I KNOW IT'S COOLANT CUASE I COULD SMELL IT AND WHEN U TAKE OFF THE RADIATOR CAP U CAN'T SEE ANY COOLANT MAYBE 1 OF THE O-RINGS SLIPED OFF THE DOMES IDK MAYBE THE COOLHEAD HAS A CRACK IN I IDK ANY HELP WOULD BE GREAT I'M ABOUT TO JUST GET A NOSS HEAD AND SEE IF IT STILL HAPPENS.
THANKS
I had a O-ring slip out of my cool head and it started to smoke like hell out of the right side. So I had to pull the head again and sure enough I had smashed on of the o-rings in the middle section of the cool head. Theres nothin gyou can do with out taking it apart and checkin it out.
i suggest tearing the head back off and inspecting the rings once again. i had the same prob, i got yamabond sealent ,its this red stuff when theres no more oxygen it dryes. i just rubbeed a dab around all the orings and it solved my problem.
like are you guys taking about when antifreeze spills on the pipe? cause mine does that on the right side and smoke and u can tell its antifrreze from the smell. i checked the hoses and nothing so maybe do i have the same problem?
288685[/snapback]
yours is not the same his is coming out of his pipes not just dripping on them like yours... yours is prolly just getting lil hott like most banshee;s you should get a billet water impellar and some inline coolers... then put in some engine ice. and move the overflow to the front of the shee in between the a arms....
i moved my bottle and packed the sides of the radiater with foam and put an in line cooler, used the water wetter. works good. Almost sounds like a water jacket gave way, but most likely yer head
its either leaky head on the side or your water pump seal is goin bad. id check the head first and make sure the o rings are correctly in place. if thats fine then id pull the clutch cover and check the water pump seal. its gotta be one or the other.
