bansheelover Posted November 30, 2004 Report Share Posted November 30, 2004 JESUS H. CHRIST these things never stay tight !!!! they move vertically and when one is tight the other one gets loose..... HOW DO U GUYS DEAL WITH THIS !!!!!!!! Quote Link to comment Share on other sites More sharing options...
Redlined Posted November 30, 2004 Report Share Posted November 30, 2004 Are you having a problem with the bolt backing out? If so I would Use loctite. http://www.spankysparts.com/red-loctite.html If the bolt is staying tight but the bracket is coming loose and moving down. That would mean that the axle is moving forward enough to allow the tensioner to fall down. One thing you can do to help reduce this problem is to grind a small notch in the a-arm were the tensioner bolt comes in contact. This will help keep it in place. Then you need to find out why the axle is moving forward. Quote Link to comment Share on other sites More sharing options...
Shaggy Posted November 30, 2004 Report Share Posted November 30, 2004 get a roundhousing swingarm that they should come with stock, that will solve any and all chaintensioning problems......it did for me Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted December 1, 2004 Report Share Posted December 1, 2004 get a roundhousing swingarm that they should come with stock, that will solve any and all chaintensioning problems......it did for me 286730[/snapback] Yep. I too faught with mine the whole time I ran a stock swinger. Simple Solution.... Quote Link to comment Share on other sites More sharing options...
mat Posted December 1, 2004 Report Share Posted December 1, 2004 They won't move vertically if the carrier bolts are tight. Is this happening while your ride? If so, you need to tighted the bottom bolt tighter. If this is happening while you are in the middle of an adjustment, the don't loosen the bottom bolt as much. Leave everything compressed a little so that they adjusted won't fall down, but loose enough that you can still move the carrier. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted December 1, 2004 Report Share Posted December 1, 2004 Like mat said, they have to be tight. I also switch to nylon locking nuts. Quote Link to comment Share on other sites More sharing options...
NYUK Posted December 1, 2004 Report Share Posted December 1, 2004 JESUS H. CHRISTthese things never stay tight !!!! they move vertically and when one is tight the other one gets loose..... HOW DO U GUYS DEAL WITH THIS !!!!!!!! 286589[/snapback] round house carrier. Quote Link to comment Share on other sites More sharing options...
racer Posted December 2, 2004 Report Share Posted December 2, 2004 i used thermo-electrical persuasion to keep my carrier in place. Quote Link to comment Share on other sites More sharing options...
SICK BOY Posted December 31, 2004 Report Share Posted December 31, 2004 I keep my carrier bolts nice and tight,and never had a problem. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 2, 2005 Report Share Posted January 2, 2005 round house carrier. 287490[/snapback] i second that... Quote Link to comment Share on other sites More sharing options...
Cotton eyed Joe Posted January 2, 2005 Report Share Posted January 2, 2005 i second that... 300696[/snapback] I'll third that. Quote Link to comment Share on other sites More sharing options...
kellam Posted January 3, 2005 Report Share Posted January 3, 2005 who cares just ride untill your chain is too loose to stay on the sprokets and busts a gaping hole in your case. then use jb weld to fix the hole and put the chain back on for the rest of the ride Quote Link to comment Share on other sites More sharing options...
FlatTrackinIt55 Posted January 4, 2005 Report Share Posted January 4, 2005 I'll third that. 300729[/snapback] i fourth that Quote Link to comment Share on other sites More sharing options...
23champ Posted January 11, 2005 Report Share Posted January 11, 2005 I will have to agree, Yamaha has a PISS POOR design for the chain tensioners. Acually the whole damn swingarm is a heep of shit if you ask me. The thing must weigh in at 20 lbs... I feel your pain bro. Quote Link to comment Share on other sites More sharing options...
John19 Posted January 19, 2005 Report Share Posted January 19, 2005 i fourth that 301687[/snapback] I fifth that... Quote Link to comment Share on other sites More sharing options...
