PolyKarbon Posted November 17, 2004 Report Posted November 17, 2004 (edited) Alright, I have a 2001 banshee. Wiseco pistons bored just a bit (not sure the new size), Boyesen "rad valve (whatever)" reeds, proflow air filter, stock carbs,and fmf gold series pipes. I run Motul at 50:1, thats what the dealer told me. Everything is fine in the shee, but I just wanted to see if the premix is at the right ratio. Thanks. PS- I have shock covers too...lol. Edited November 17, 2004 by PolyKarbon Quote
BenBB Posted November 17, 2004 Report Posted November 17, 2004 Oh well shock covers that changes everything , heh j/k. Mix the oil to what the oil manufacturer recommends, if it says it's ok to run at 50:1 that will work...IF you're jetted for it. When you change ratios it will affect the air/fuel ratio and hence the jetting will be affected. There isn't really a right or wrong oil ratio, just different oils, 32:1 is probably the most common but people will run anything from 20:1 to 100:1 (with the appropriate oil). Quote
nickxc Posted November 17, 2004 Report Posted November 17, 2004 Alright, I have a 2001 banshee. Wiseco pistons bored just a bit (not sure the new size), Boyesen "rad valve (whatever)" reeds, proflow air filter, stock carbs,and fmf gold series pipes. I run Motul at 50:1, thats what the dealer told me. Everything is fine in the shee, but I just wanted to see if the premix is at the right ratio. Thanks. PS- I have shock covers too...lol. 282182[/snapback] thats prolly fine. I know alot of guys run at 50:1 I dont know much about the type of oil you are useing. I personally run amsoil dominator at 32:1 alot of guys run this oil at 50:1 like the bottle says you can but I dont mind useing a little more oil just cause it burns so clean you dont even notice it and oil is cheaper than parts. plus I run down the road wide open alot so I dont mind having a little more oil to my motor... Personally if you arnt having any problems just keep running it like that. or if you are concerned just start running alittle more oil maybe a 40:1 or sumthin. Really your call... Quote
SICK BOY Posted November 17, 2004 Report Posted November 17, 2004 I run Motul Factory Line 800 pre mix,mixed at 60:1. Quote
stu Posted November 18, 2004 Report Posted November 18, 2004 im running synthetic rock oil at 40:1 and never had any problems....apart from my failure to dial her in perfectly so ive been studying BenBB's jetting FAQ! stu Quote
Wassup350 Posted November 18, 2004 Report Posted November 18, 2004 AMSOIL series 2000 racing oil (think thats right, not sure though) @ 40:1. I personnaly think with a good oil 40:1 is a good ratio. I never have any problems fouling plugs or boggin down and its just a tad richer then 50:1. Quote
RNBRAD Posted November 18, 2004 Report Posted November 18, 2004 mobil 1 @40:1 282512[/snapback] Quote
tats4life Posted November 18, 2004 Report Posted November 18, 2004 motul 50:1 free riding......race day 60:1 Quote
moookie132 Posted November 19, 2004 Report Posted November 19, 2004 anything got anything bad to say about yamalube? Quote
FIRST BANSHEE Posted November 19, 2004 Report Posted November 19, 2004 I have always run my 2- strokes at 32-1, I like the extra oil for the bottomend. Quote
