What kind of rear tires are good for dirt drags? I have some 20" ITP holeshots to try, but don't know if they are good enough to do battle against the other types. They are brand new so they probably aren't too bad, but what does everybody else run for dirt drags? Thanks!
A lot of dirt drag racers use the tires shaped like just4snow or the wollyberger type at 2psi. The wollyberger will grip really good then expand like a top fuel dragster.
Edited by fixitrod
Pro wedge 2
Ohtsu radial like a honda factory tire
Grooved turf tamers
4 snows
I see alot of these around here.I run the turf tamer with every 4th row cut out.With the turf tamers and the chassis set-up I have I can bring the tires off the ground at the starting line and carry them about 5 or 6 inches from the ground the whole way to the finish line.Thats 600ft dirt.It's a bitch if you get sideways though.
