Rescuejeff Posted July 1, 2004 Report Share Posted July 1, 2004 I was wondering from all the members some questions about the airscrews. First off, when you screw it in, you just go til it stops turning obviously, right. Then when your tunring it back out as some members have 2.5 turns out, so that is two complete turns out with another half right??? Still trying to understand some the terminology you guys have and I am very weak when it comes to the carbs, but trying to get better. Thanks. Quote Link to comment Share on other sites More sharing options...
dave95.1 Posted July 1, 2004 Report Share Posted July 1, 2004 that would be correct. when you turn them in until they stop make sure not to tighten them any. Quote Link to comment Share on other sites More sharing options...
jlh Posted July 1, 2004 Report Share Posted July 1, 2004 Yes you turn it out two and a half time's Quote Link to comment Share on other sites More sharing options...
hill climb Posted July 3, 2004 Report Share Posted July 3, 2004 adjusting the air screw will help with idle correct? Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted July 3, 2004 Report Share Posted July 3, 2004 Indirectly yes, but if your idle's bad, you should adjust the idle screw or knob. Once it's idling good, then monkey with the air screw and after you fidget with that, then adjust the idle again until you achive your desired results. Quote Link to comment Share on other sites More sharing options...
hillcrazedbanshee Posted July 4, 2004 Report Share Posted July 4, 2004 being an older banshee make sure your cables are in sync to get it dialed in correctly. Quote Link to comment Share on other sites More sharing options...
