Hockey390 Posted May 20, 2004 Report Posted May 20, 2004 (edited) hey, just wanted to start a new topic cause that one has soooo much stuff on it. http://www.bansheehq.com/forums/index.php?...opic=28553&st=0 that was it... Just pulled the pipes off, and I got a suprise... APPRX. 1/2 gallon of came out of each pipe.. EACH PIPE here are pics.... I think that is my problem. Compression wise, maybe still low...who knows, but I'm airing them out, here are pics.. thats the floor....took one off and went to set it down...ALL OVER! this is the bucket from half of one... nother of the floor... Think this is why I have spark, gas, and no spark??? ***EDIT*** sorry, meant spark, gas, and no fire... Edited May 20, 2004 by Hockey390 Quote
sredish Posted May 20, 2004 Report Posted May 20, 2004 Damn dude, I don't know whatsup with all that oil. Ha, bet your machine was feelin a little heavier than normal. Gots to go, but I'll think about it. Quote
cdcoxwell Posted May 25, 2004 Report Posted May 25, 2004 Hockey, is that just oil, where did it come from and what are you doing to correct it. I've never seen anything like this so feel free to explain slowly because I have an 87' as well and it maybe something I need to do as well. Quote
H300F Posted May 26, 2004 Report Posted May 26, 2004 Hey, your bottom end should be filled with gas to so dont forget to get that out. Stuck needle valve in the carb/carbs??? Quote
J..J. Posted May 26, 2004 Report Posted May 26, 2004 WTF? I'll definetely have to put that one in the li'l black book... Quote
banshee04le Posted May 26, 2004 Report Posted May 26, 2004 Yeah, one of the float valves in your carbs must have stuck open and you must also have a problem with one or both of your overflow tubes. Pinched, kinked or otherwise plugged up. Make sure you clear your overflow tubes so this doesn't happen to you again. Quote
nater006 Posted May 26, 2004 Report Posted May 26, 2004 I'll third the notion about stuck needle valves and clogged overflows. My tecate4 used to have the fuel run right through the motor like that. The first time I didn't know and got it actually started, it sprayed everywhere out the silencer. That sounds like a potential. Quote
Banchetta Posted May 27, 2004 Report Posted May 27, 2004 I'll 5th that oppinion. STuck float valves in the carbs....make sure you get the gas out of the lower end as well, you'll be able to top that bucket off.... Quote
Blacksmith Posted May 27, 2004 Report Posted May 27, 2004 I would take the tank and tank plastic off of that bike and turn it upside down with the plugs out and turn it over a couple of hundred times. :-) This will get that crap out of your bottom end. Clean your carbs and check the float bowl levels and needle valves. Then put that thing back together and see if you can get it to start. Good Luck. Quote
