I've always stuck with NGK BR8ES and never had a problem. Last I heard Splitfire was a gimmick, although the link someone posted a while back about cutting the ground strap might hold some water...
I don't think there's anything wrong with the BR8ES, great plug. I began using a BR8EIX plug about three or four months ago and I really like it. Seems to burn a lot cleaner and stronger. If your changing elevation much and you go up a little that would normally be on the rich side of the line, this plug will help burn cleaner and not foul as easy. This plug has been the standard in jet ski / watercraft racing also.
Like I said, there is nothing wrong with the standard plug and it works well, but the Iridium is a very nice plug also, if you don't mind paying a little more.
Later.
