LIsurfer_ Posted April 30, 2004 Report Posted April 30, 2004 I just checked em today. Left is 90 right was 85. So now that I KNOW I need a rebuild what should I expect to pay. This is definately not soemthing I want to try. Quote
yamaha350 Posted April 30, 2004 Report Posted April 30, 2004 it is easy to do. tke the cylinders off and get them bored. that will run about 80. new pistons are 120 - 150. get wisecos. slap it back together and go. buy a clymer manual if you arent sure about youself. it will help alaot. Quote
frocashmoney24 Posted April 30, 2004 Report Posted April 30, 2004 s dead on, get a clymers maual for 25 , its owrth it, ask any more questiosn if u have em Quote
Rescuejeff Posted April 30, 2004 Report Posted April 30, 2004 Best thing about that is the torque ratings, or spend the big bucks and get the Yamaha version. Quote
SDD Posted April 30, 2004 Report Posted April 30, 2004 Before you tear it down for a new topend you might want to try a better gauge if you have a cheap/old one. What altitude and what tempature are you taking the kicking compression tests at? You should measure your cylinders before boring them to be sure it's really neccessary. The problem is actually measuring them out. You need some specific tools to get the info you need to make the decision. If everything is in check maybe just rings are in order to get things back up to where they should be. Quote
LIsurfer_ Posted April 30, 2004 Author Report Posted April 30, 2004 The temp was in the 70's yesterday and I am @ 1000 above sea level. If I pull the jugs I will probably take them to a local shop to get bored / honed depending on what they say they need. The guage was a fairly new one not a real cheapy. I have been having a hard time starting and it was reccomended that I check compression. I do not really have a hard time believing that it was a true reading. Quote
nickxc Posted April 30, 2004 Report Posted April 30, 2004 Even if it wasn't a true reading its prolly close enough that you should freshen up. If your gunna pull your top end down youd be crazy to just throw in a set of rings and put it back together for what it costs to do a good job its worth it. get a fresh bore it will make everything a lot tighter... over time cylinders get out of round and need to have a fresh bore. also I would consider vitos pistons. I'v used them and the performance shop that does all my work uses them in some of their banshees and we have had good luck with nice performance results from them. Quote
knight_ripper Posted April 30, 2004 Report Posted April 30, 2004 lil surfer.... what year is your shee? Quote
LIsurfer_ Posted April 30, 2004 Author Report Posted April 30, 2004 it is a 2000........and I have to share this...I call up the mom and pop engine/machine shop to get a price on boring the cylinders just incase they need it....holy shit this Idiot argues with me over wether or not my 4 wheeler is a 2 cylinder and then tells me it will be $300.oo to do 2 cylinders...yes $300.00 i couldnt stop laughing and just hung up...what the shit........Next call was to a NAPA store for $40.00 per cylinder they can do it in 24 hours...... Quote
sheerider4life Posted April 30, 2004 Report Posted April 30, 2004 It seems like u guys are paying pay to much i can get it for twentyeight $ its cheap send me your cylinders i can get them done for that cheap Quote
2004LEBanshee Posted April 30, 2004 Report Posted April 30, 2004 Not sure what your mods ar but you could also get your crank welded now. Quote
