Air leak in the exhaust. Did you put those o-rings in the pipes before you put em on? Plugs look good right? You might not have a good seal.
Are you running the Orings for that intake?
If so that maybe the problem.
When I had mine I used regular intake gaskets.
Then I had rebuilt my motor and onlly had one set of gaskets.
so I used those and the orings and less than1 hr on my new motor
it blew up on the left side. :angry: . Yes my intakes where tight.
So I blamed the problem on them. Put new piston in it, put my stock intakes back
on and carbs. No problems yet. Infact I like it better
The trinity seemed to run flat at wot. And I diddnt see that much
bottomend loss. When I put it on I put other stuff on to so I didnt know how much it helped. Until I went back stock, and I like the duals. The water sux wit stock carbs so Ill be going to flatslide 28s soon.
Hope this helps.
Going to try a new o ring in the exhaust today I know I don't have an intake leak sprayed it with carb cleaner and it didn't make a diff to the revs. Will let ya'll know what I find out
