i can get a good deal on a graydon proline 2 into 1 but it has 36mm keihin with it i was wondering if this will be too big.my mods are 60.over,dmc pipes,boyesen reeds,+2 timing advance.i plan to have a mild port job in the future
It'd work good, and would be even greater with a port job.
What do you run? Dunes? Mx? Drag? The 36 will cause you to loose a bit on the bottom..even with a 2 to 1 setup. I'd get a 32 or 34 for the 2 to 1.
i mostly ride trails i live in southern indiana so not alot of wide open spaces
that carb will work really good for you, especially with the DMCs. It will also be a great trail carb with your future port.
