  • 2 weeks later...
Yeah, definitely check out the setup from Alba. If I'm remembering right, they use the Nitrous Express wet kit. A wet kit is by far the best way to go for consistency. A friend of mine used the NX wet kit all last year with no problems.
Whatever you do though, make sure your motor is ready for it. Forged pistons and a welded crank are a must.
  • 4 weeks later...
A lot of people recomend the boon dockers but I have heard that you have to jet rich and run that way all the time but on the wet kit your jetting stays the same. Is that true? Also what do you set your timing for with nos.
from what i have read u dont have to change your jetting.. your timing is a whole diffrent story for nitrous the timing had to be retarded, i'm not sure exactly how much but from the few peeps i know who have run it its like -11 or -12 degrees.
I am running a NX set up this year. That kit says you only need to back your timing off 2-4 degrees from your normal set-up. I will also be running a progressive control from schnitz, so I will only shoot like 25% of my overall shot for the first 1-1.5 seconds. Then hold on.
