canadabanshee
Everything posted by canadabanshee
  1. The screws are great they are lasting good. AmA screws do not rust like the regular ones do. And are very sharp. You have to see them. They have a cup and a groove in the centre.
  2. Hey guys thanks thats all I am asking for. Its got balls in fifth but not sixth So i know it can not take it. So what gears would be the best.
  3. But it pulls good till that gear. And just crusies in 6 th. I have pro curict pipes, bottle boost,k&n air filter,rtc clutch,jets,and wiseco 30 over pistons.
  4. I just put a 17 front sproket on with a 41 in the rear. It pulls great to fifth. but in 6 it does not go like when i had the stock front sproket on. There is no power band with the 17 sproket in 6 thgear. I dont get it. It goes great up to 6 th gear. It pulls great. when I am in fifth I shift when it sounds good high rpms to. So any clues
  5. Hi I just got a 17 front sproket. I have a 41 on the rear. How many links do I need. I cant get it right
  6. it comes with everything. cables and all. Its great in the open. But its different over bumps. You gotta try it to see how you like it
  7. Hey its easy to do. Goes on fast. But to tell you the truth dont get it. I got it cause I drove dirt bikes before I got the banshee. So I got it for the banshee and it not the same I dont like it. So I am going to switch it back.
  8. A buddy gave me a 13 tooth front sproket. should I try it. Good for low end. with a 41 stock on back. I have a 14 and 41 now
  9. Hey I need a good chain that does not have to adjust so many times. I think its called a X chain not to sure. But they can take a lot of shit. And sprokets what are some good types and what sizes. Stock they are 14front 41 back. I pt pipes and reeds on my banshee. I was thinking 40 back and 15 up front. What do u think about that. Top end good but will I still have good low end pull.
  10. Hey. Last winter I put 250 studs per tire. I got a box of ice racing screws. I think they come in boxes of 500 1000 or 2000. They worked great. I was doing wheelies on the ice. I would use these over self taping screws cause they have a dish in the centre of the head that bites into the ice. Helps out good. I used a cordless drill to put them all in. But if you have no tread on the tires its ok. They come in different lenghts to. Or if they do go throw the tires making it flat. You can go get this green gop tire flat stuff works great.
  11. What kind of sprockets and chain should I get. What company makes the best. And for low end power how many teeth on the front and how many teeth on the rear should I get.
  12. Right on man. I blew them out. She is starting good. One or two kicks. Thanks
  13. how do you do that.. setting the bowls
  14. Yea everything is tight. Spark plugs, head, carbs and the boots. reeds. all good
  15. I have a new banshee. I put reeds and pro cucurit pipes on it. It was running good in the winter. But when it got warm it would not start. I tryed lots of different jets in it to. But If I spray some gas into the carbs it starts. It runs great. Only on cold start up. If I let it sit for over a hour it will not start. I dunno what to do. It gets lots of gas. She still goes fast. Good compression. around 125 if i remeber right. what should I try next.
  16. canadabanshee
    Nos
    What can a stock engine take of nos how many shot of nos can you give it. What is the best set up to get.
  17. I think its clutch trouble. Wehn I run my banshee pull in the clutch and put it in gear it does not go anywhere. When its just sitting not running and I put it in gear it does not go in gear. Cause you can feel it roll free on the ground. It feels like when I shirt that the gears are good still shifts to all gears.
  18. what is the compression of the clylindres for the 2003 banshee
  19. yes I did its 260. I am getting 280. gears are stock ones. Should I change them.
  20. Today I got a friend in his truck to see how fast I can go. It turned out to be 135 km. I have a 2003 banshee. JUst has pro cuirt pipes thats all nothine esle. IS that how fast it should be what esle should I do for top speed
  21. stock carbs and filter
  22. I got boyesne reeds today. I have pro curicuit pipes to. What should I do to the carb shoul I change the mains or any other settings. I got 220 in it
  23. How many liters is the res in the tank. And a average of how many km can you get on the reserve.
  24. I got a stock banshee just with pro curicuit pipes. What is a good tire I should run. What size should I get or just run the stock size. How many ply. I ride in sand and hard pack and mud
  25. I have a 03 banshee with pro curicuit pipes. What would be the best air filter and spacer. And what reeds and spacer to run
