The screws are great they are lasting good. AmA screws do not rust like the regular ones do. And are very sharp. You have to see them. They have a cup and a groove in the centre.
But it pulls good till that gear. And just crusies in 6 th. I have pro curict pipes, bottle boost,k&n air filter,rtc clutch,jets,and wiseco 30 over pistons.
I just put a 17 front sproket on with a 41 in the rear. It pulls great to fifth. but in 6 it does not go like when i had the stock front sproket on. There is no power band with the 17 sproket in 6 thgear. I dont get it. It goes great up to 6 th gear. It pulls great. when I am in fifth I shift when it sounds good high rpms to. So any clues
Hey its easy to do. Goes on fast. But to tell you the truth dont get it. I got it cause I drove dirt bikes before I got the banshee. So I got it for the banshee and it not the same I dont like it. So I am going to switch it back.
Hey I need a good chain that does not have to adjust so many times. I think its called a X chain not to sure. But they can take a lot of shit. And sprokets what are some good types and what sizes. Stock they are 14front 41 back. I pt pipes and reeds on my banshee. I was thinking 40 back and 15 up front. What do u think about that. Top end good but will I still have good low end pull.
Hey. Last winter I put 250 studs per tire. I got a box of ice racing screws. I think they come in boxes of 500 1000 or 2000. They worked great. I was doing wheelies on the ice. I would use these over self taping screws cause they have a dish in the centre of the head that bites into the ice. Helps out good. I used a cordless drill to put them all in. But if you have no tread on the tires its ok. They come in different lenghts to. Or if they do go throw the tires making it flat. You can go get this green gop tire flat stuff works great.
What kind of sprockets and chain should I get. What company makes the best. And for low end power how many teeth on the front and how many teeth on the rear should I get.
I have a new banshee. I put reeds and pro cucurit pipes on it. It was running good in the winter. But when it got warm it would not start. I tryed lots of different jets in it to. But If I spray some gas into the carbs it starts. It runs great. Only on cold start up. If I let it sit for over a hour it will not start. I dunno what to do. It gets lots of gas. She still goes fast. Good compression. around 125 if i remeber right. what should I try next.
