reas11 Posted February 23, 2004 Report Posted February 23, 2004 what do u mean by problems? i don't understand as long as u line up the line with the case split mark it should be ok . what kind of problems are u having ? rickystator is one of the top names in the business, did u even install it yet ? Quote
04Banshee Posted February 24, 2004 Author Report Posted February 24, 2004 No, I was wondering if the ricky stator plate is any good. If anyone had any problems with it. I was looking to buy one. I dont have one yet. Sorry for the confusion. Quote
Cannon Posted February 24, 2004 Report Posted February 24, 2004 I have the Ricky Stator adjustable plate. It is a good mod IMO. Set mine at +4, bike runs great. You don't have to rejet. $35. plus ship. Easy to do after the help I got from guys on this forum. (Thanks Meat) You'll like the advance no matter which plate or route you use to get there. Quote
2banshees Posted February 25, 2004 Report Posted February 25, 2004 dont go nuts on advancing your timing. more is not better. if you go too far it will run HOTT. +3 or 4 usually works well. mine ran hott at 7 and ive got all the stuff you can buy to keep it cool. hope this helps Quote
Bense Posted February 25, 2004 Report Posted February 25, 2004 Anyone have tricks for putting these on without buying the puller? Quote
Cannon Posted February 26, 2004 Report Posted February 26, 2004 You will need a flywheel puller. Make sure you use one designed for this flywheel so you don't damage it. Their not too expensive, or you could borrow one from a buddy. Air tools help alot when getting the wheel loosened too. Meat helped me with great instructions to do mine. Let me know if you want a copy of it. Wasn't too hard at all and I learned a little more about our ride. Quote
04Banshee Posted February 26, 2004 Author Report Posted February 26, 2004 Can anyone tell me why the ricky stator is only $35 and all the other ones are like $100? Quote
