How do I get rid of this cluster, I am getting new carbs PJ-34s so I don't have the tors anymore. Can I just take this crap off now? Before you couldn't run it above idle with the parking brake on.
I've got my computer in the exact same spot.  No problems yet but I haven't rolled my shee.
I put it down low like that because I was afraid that if I did roll it I wouldnt mess it up.
I have my Trail Tech speedo mounted in the same place that you do (low by the clamp).I like it there,it's easy to see and lesslikley to get banged up.
Get rid of the cluster by removing the entire parking brake assembly, get a block off plate for the rear caliper, and step-up to the best clutch perch / lever in existince "RTC" levers this is the "Pro Pull" version, needle bearing quick adjust, 2 position cable mount. Best money I've spent on controls
bottom view
Dunedemon.
That RTC clutch perch looks damn near identical to my MSR Raptor perch. I wouldn't have another MSR perch to save my ass. I imagine the RTC perch is built better. Looks good. ;)
My g/f's dad ground off the barking break assymbly on his perch & repainted it. Looks like an aftermarket perch now but it's still the stock one.
hell yea brian from rtc is awesome, he hooks you up with some good shit, i have the same clutch setup except not with red, did you do that yourself?
