Im-Loving-It 69 Posted January 13, 2004 Report Posted January 13, 2004 People have toled me in the past that i shouldent do to much to a banshee with a stock crank unless i get it weled because thay spin apart is this true? because if so im not even going to ride it till i get a new one Quote
blk02banshee Posted January 13, 2004 Report Posted January 13, 2004 Yes, they can get out of alignment, but as long as you don't have too high of compression, and no porting, the stock one should last quite a while. Getting the crank welded is a good thing, though. Quote
SandBastard Posted January 14, 2004 Report Posted January 14, 2004 you dont have to buy a whole new crank, you can have your original crank checked and trued by a qualified mechanic who will tell you if it needs repair. If its ok just have it trued and welded, probably only 75 dollars if you bring him just the crank. I took mine out to have it welded and it had begun to separate. I only had pipes and intake at the time. welding the crank is cheap insurance against possible case damage, but not really neccesary on a stock or close to stock bike. Quote
Im-Loving-It 69 Posted January 14, 2004 Author Report Posted January 14, 2004 Well i have a boondockers nitrous kit, pipes,K&n,bored 20 over vetos pistons,cool head with 22cc domes. Quote
BansheeJerry Posted January 14, 2004 Report Posted January 14, 2004 Is there any way to tell if the crank is seperating without splitting the cases and phisically looking at the crank? Will it make any noises or run bad or anything? In other words are there any warning signs before it is too late? Quote
Dextreme Posted January 14, 2004 Report Posted January 14, 2004 BansheeJerry, no way that I know if. If it starts running bad...its probably too late. I am having my welded right now and it was starting to separate (only 25 thousands), yet the motor "appeared" to be fine. Quote
shortys racing Posted January 14, 2004 Report Posted January 14, 2004 Is there any way to tell if the crank is seperating without splitting the cases and phisically looking at the crank? Will it make any noises or run bad or anything? In other words are there any warning signs before it is too late? Dex is right, by the time it is making noises it is already rubbing on the sides of the cases sending pieces of alum. threw your motor. Welded crank is the first thing you should do when your bottom end is apart. No exceptions!!! Just a good insurance policy for later. Quote
BansheeJerry Posted January 14, 2004 Report Posted January 14, 2004 Well that sux. I will ask you all this then. I bought my shee from my sister in law. She bought it brand new for her 12 year old son so it never really was riden hard or much until I got it. It sure was abused though..I have had it for almost a year now. I ride on average 60 - 70 miles a month. When I first brought my shee home the tranny oil was milky and looked like it had never been changed. I changed the oil before I even started it up. The clutch went south a couple months after I got it,From the shitty oil needless to say. I now change it every 3 rides or so. The kid knew nothign about the shee and was running regular 10w40 for the premix. It took a while for her to clear up to say the least! Compression is great in both jugs @130psi. Basically I am asking with the info I just told you would it be feasable to split the cases just to weld the crank or should I cross my fingers and hope it doesnt seperate and weld it when I have to split the cases? There is some sort of gear noise in the bottom end. It has done it since I have owned it. Could this be the crank seperating? Man you all have me worried now Quote
Justintoxicated Posted January 14, 2004 Report Posted January 14, 2004 cheapest place I found around here was $90m every other place wanted about 130-150 but to $200... Thats what I get for living in San Diego though I guess. Quote
FULL_METAL_JACKT Posted January 14, 2004 Report Posted January 14, 2004 damn dude here in Miami wants 25 buks to weld it! Quote
Justintoxicated Posted January 14, 2004 Report Posted January 14, 2004 damn dude here in Miami wants 25 buks to weld it! I meant to say for true and weld, I probably could have had it welded for free, but not trued. Quote
BansheeJerry Posted January 15, 2004 Report Posted January 15, 2004 This really answers my questions... Thanks guys... Is this the blaster forum?? I guess I need a few more beers... Will be back in a bit.. Quote
shortys racing Posted January 15, 2004 Report Posted January 15, 2004 This really answers my questions... Thanks guys... Is this the blaster forum?? I guess I need a few more beers... Will be back in a bit.. well it's really up to you.....I would do it as soon as possible. these things could do it tomorrow or 5 years from now...we don't know. True & welding would cost $45 usually. It's just the labor to take it apart, if you can do that then your $$$ in the bank. Could be now....it sounds more like a growling noise..... Quote
BansheeJerry Posted January 15, 2004 Report Posted January 15, 2004 I guess I was a little slow tonight.. Quote
Im-Loving-It 69 Posted January 16, 2004 Author Report Posted January 16, 2004 Ok im going to split my case could any one tell me how to do it or show me some pitchers on it .. Quote
