Keithrc1988 Posted March 9 Author Report Posted March 9 Back to working on banshee again, did compression test and only have 65psi on left And 75psi on the right. Quote
375hp banshees Posted March 9 Report Posted March 9 But it runs so... again Jack it up & start it, pull clutch, put in 1st, if tires spin> clutch If not, feather the clutch release. report back Quote
Keithrc1988 Posted March 9 Author Report Posted March 9 On 12/31/2025 at 10:41 PM, 375hp banshees said: Sound like you figured it out... replace jets, to fix a clutch problem ftw Like I Said before the clutch is not the issue it engages and disengages like it supposed to… Quote
375hp banshees Posted March 9 Report Posted March 9 Then why does it shut off, when you put it in gear? Quote
T13 Posted March 10 Report Posted March 10 What year is this machine? Possibly the park brake safety switch Quote
Keithrc1988 Posted March 12 Author Report Posted March 12 On 3/9/2026 at 9:38 AM, 375hp banshees said: Then why does it shut off, when you put it in gear? It doesn’t just die, it starts spitting and pooping and bogging then dies. Took off head it appears to have sucked up metal from bottom end through ports And ruined pistons and domes again. Quote
