Keithrc1988
Recent Profile Visitors
777 profile views
Keithrc1988's Achievements
  1. It doesn’t just die, it starts spitting and pooping and bogging then dies. Took off head it appears to have sucked up metal from bottom end through ports And ruined pistons and domes again.
  2. Like I Said before the clutch is not the issue it engages and disengages like it supposed to…
  3. Back to working on banshee again, did compression test and only have 65psi on left And 75psi on the right.
  4. Clutch is working fine. I bought bigger pilots jet kit gonna try that. I had 55 in it already then bored it to 68.50. I ordered 55-80 jets
  5. Clutch is disengage and engaging just fine
  6. Just rebuild it and bored it to 68.50.
  7. I just rebuilt it and went from Stock to 68.50. This was first time starting it up. Have 28 mm kehien carbs with 160 main and 55 pilot. Air box with no lid and k and n filter.
  8. My banshee starts and runs fine in neutral, but as soon as you shift it into first or second it dies. Doesn’t matter if clutch pulled in or not, and it’s not dragging or sticking.
  9. This place is stupid asf nobody puts how they solved problem just a bunch of what’s your jetting and altitude like come the fuck on people
  10. This place is stupid asf nobody puts how they solved problem just a bunch of what’s your jetting and altitude like come the fuck on people
  11. I having same issue with my banshee
  12. Have 98 banshee was running perfect and I got on to ride it and it started went about 50 ft and died. Now it starts and runs for a few seconds and dies and backfires sometimes when kicking it over. I replaced coil and head gasket and checked compression and everything good there and ideas on what’s could be going on? I suspect electrical issue
  13. Did you figure out this issue? My banshee is doing same thing
