Probably not this year but I want to start to get a plan on parts I will need to swap out my busted case. I really have no issues with the banshee other than a few shifting issues. At a high rpm I seem to miss 3rd, I try again and it will but its annoying. I've put in the HD springs and clutch plates from Drivelive and replaced the clutch handle and this was a problem before. The bigger of the annoying issues is trying to find neutral. This has always been dumb and embarrassing when I can't find it lol.. I am not sure what mods have been done but I am sure it wasn't done right.
Just wanted to get a parts list of things I should probably replace while in the case. The bottom and top end are newer with less than 5 hours it.
I would do pro mod certainly.
New shift shaft and spring
New Eccentric screw
New oem clutch cable
Finding neutral can be difficult. sometimes a modded star will help and having a well adjusted cable will help.  Sometimes you learn to get neutral before you come to a complete stop or just find it after you shut it off. The clutch basket can also have grooves in it causing clutches to drag. Consider a billet basket.
