realdesertkickin Posted May 20, 2024 Report Posted May 20, 2024 New and learning here... Is this hole legit?.. it doesn't line up with the drain hole under the carbs... It's not leaking and the bike runs fine... Quote
realdesertkickin Posted May 20, 2024 Author Report Posted May 20, 2024 3 minutes ago, realdesertkickin said: New and learning here... Is this hole legit?.. it doesn't line up with the drain hole under the carbs... It's not leaking and the bike runs fine... sorry pic didnt post....figuring out delete now Quote
specialblend07 Posted May 20, 2024 Report Posted May 20, 2024 If it's the hole on the cases, yes, it's legit Quote
locogato11283 Posted May 20, 2024 Report Posted May 20, 2024 Drain hole from top of case. Nothing to worry about. Quote
realdesertkickin Posted May 20, 2024 Author Report Posted May 20, 2024 OK thanks!! appreciate it...... Quote
specialblend07 Posted May 20, 2024 Report Posted May 20, 2024 1 hour ago, realdesertkickin said: OK thanks!! appreciate it...... You're welcome. Quote
SKEETER Posted May 20, 2024 Report Posted May 20, 2024 Had much higher Hope's for what this was gonna be 1 Quote
