Josh96 Posted March 24, 2024 Report Posted March 24, 2024 So I was riding in my neighborhood and my banshee started sounding weird so I go back to the house as I’m pulling up/ slowing down the banshee just revved up high on its own, got it to turn off after scaring tf out of me then noticed my stinger pipe came off the silencer due to screws falling out and was hanging causing the stinger to come off the body pipe as well question is was that the reason why it did the death rev?…. Thanks in advance 🙏 Quote
Josh96 Posted March 24, 2024 Author Report Posted March 24, 2024 I put the stinger back on the body pipe and to the silencer took it back out and was/ sounding ok just stuck between if it was a air leak or the exhaust falling off that caused it to rev up ??? Quote
375hp banshees Posted March 24, 2024 Report Posted March 24, 2024 https://www.bansheehq.com/forums/topic/149593-exhaust-question/#comment-1947158 Quote
hoppedupandcutdown Posted March 24, 2024 Report Posted March 24, 2024 usually happens when running out of fuel, or sticking slide or cable. Quote
Josh96 Posted March 24, 2024 Author Report Posted March 24, 2024 Did the slide get stuck cause the exhaust came off? Quote
375hp banshees Posted March 24, 2024 Report Posted March 24, 2024 Sounds like it solved it's self? Have to wait till it does it again, and see what it is. Quote
Josh96 Posted March 25, 2024 Author Report Posted March 25, 2024 I just rode it for about an hour and it did it twice out of the hour 😌 Quote
375hp banshees Posted March 25, 2024 Report Posted March 25, 2024 Prob. Cable or slides. How are u killing it? Once it's shut off look at slides. If stuck, see if its cable causing it, if not, its the slides/bore. Quote
kawa110 Posted March 25, 2024 Report Posted March 25, 2024 Slides have a hole in them so they will close easier. sometimes the retainer holding cable to slide can be covering the hole. Sent from my iPhone using Tapatalk Quote
Josh96 Posted March 26, 2024 Author Report Posted March 26, 2024 I’m putting it in first and popping the clutch while holding the brake Quote
375hp banshees Posted March 26, 2024 Report Posted March 26, 2024 Good, then what ever is stuck, should still be stuck...to check Quote
