Up north rider Posted March 20, 2024 Report Posted March 20, 2024 I’m wondering if I would gain any power from switching from my 24cc to 23 or 22cc domes on my 421 assassin. I don’t plan on running anything higher than pump gas. My cranking psi when I built the motor was around 120. Elevation I ride Is 600-1200 ft. Quote
Up north rider Posted March 30, 2024 Author Report Posted March 30, 2024 It is the low port version as well Quote
ClaudeMachining Posted April 1, 2024 Report Posted April 1, 2024 I’m wondering if I would gain any power from switching from my 24cc to 23 or 22cc domes on my 421 assassin. I don’t plan on running anything higher than pump gas. My cranking psi when I built the motor was around 120. Elevation I ride Is 600-1200 ft. You should always run the least octane your setup can take.Do a uccr test and report back. Lower than 12, you can put smaller domes.Envoyé de mon SM-S908W en utilisant Tapatalk Quote
Up north rider Posted April 1, 2024 Author Report Posted April 1, 2024 So correct me if I’m wrong. Uccr means uncorrected compression ratio? Quote
SKEETER Posted April 1, 2024 Report Posted April 1, 2024 Easy with the big words, claude is only an e n g I n e e r Quote
Up north rider Posted April 1, 2024 Author Report Posted April 1, 2024 (edited) I don’t even know what it means. smh Edited April 1, 2024 by Up north rider Quote
ClaudeMachining Posted April 1, 2024 Report Posted April 1, 2024 Easy with the big words, claude is only an e n g I n e e r I'm way more than a simple engineer. ;-)Envoyé de mon SM-S908W en utilisant Tapatalk Quote
ClaudeMachining Posted April 1, 2024 Report Posted April 1, 2024 I don’t even know what it means. smhYes UnCorrected Compression Ratio.Your static compression is kind of low, you can probably use smaller domes, but without uccr test, it's kind of hard to tell.Bill should know the numbers by heart since he's doing this days in days out.Envoyé de mon SM-S908W en utilisant Tapatalk Quote
Up north rider Posted April 19, 2024 Author Report Posted April 19, 2024 After talking to driveline, I bought 23cc domes and it made such a huge difference! The cranking psi is now 140(cold). I know I should check it again warm just to make sure it’s not too high but I’m sure it’s pretty safe yet. I didn’t confirm the squish clearance yet either. .051-.055 is the green zone correct? Anyway I thought I’d say it’s running fantastic. I had no idea it would be such a drastic change. The cpi pipes that I have on there (I hate to admit it) kind of sucked for playing around and trail riding but now it seems to have way more mid torque. They almost feel like my old t5’s did but in addition to a lot more top end as well. I haven’t touched the jets yet but we’ll see. The thing rips! Quote
ClaudeMachining Posted April 20, 2024 Report Posted April 20, 2024 After talking to driveline, I bought 23cc domes and it made such a huge difference! The cranking psi is now 140(cold). I know I should check it again warm just to make sure it’s not too high but I’m sure it’s pretty safe yet. I didn’t confirm the squish clearance yet either. .051-.055 is the green zone correct? Anyway I thought I’d say it’s running fantastic. I had no idea it would be such a drastic change. The cpi pipes that I have on there (I hate to admit it) kind of sucked for playing around and trail riding but now it seems to have way more mid torque. They almost feel like my old t5’s did but in addition to a lot more top end as well. I haven’t touched the jets yet but we’ll see. The thing rips!Good!!!I had a DL 421, it was a great engine.Envoyé de mon SM-S908W en utilisant Tapatalk Quote
