stocker Posted March 13, 2024 Report Posted March 13, 2024 Working on a 1997 Banshee. It is completely stock except for the aftermarket chain roller. I want to install a stock chain roller. So I bought Yamaha chain roller 2gu-22151-10-00 (number 10 on the schematic) and the pipe/bushing 2gu-22155-00-00 (number 42 on schematic). Here is my dilemna since this had a aftermarket chain roller on it the stock pipe/bushing was removed from the swingarm or else I would just install the new pipe/bushing in the same spot as the old one, but its not there so I'm left guessing. This pipe/bushing is pressed on the swingarm so its not like I can assemble it and move it slightly this way or that after the swingarm is on the quad. I looked in a Clymer Manual and a Yamaha Manual. I didn't see any reference at all to this pipe/bushing. Does anyone know how far to press this pipe/bushing onto the swingarm ? And any tips on getting it pressed on the swingarm without damaging it ? I can't get my pictures to load, here is a link to a schematic https://www.yamahapartshouse.com/oemparts/a/yam/50038c7df870021f60a0b570/rear-arm Quote
JerzOutlaw350 Posted March 13, 2024 Report Posted March 13, 2024 You are better off with the aftermarket chain slider. The oem setup is prone to failure. 1 Quote
stocker Posted March 13, 2024 Author Report Posted March 13, 2024 The first picture I posted is the bushing/pipe in question. It gets pressed/ pushed onto the swing arm. The second picture is just a stock chained roller installed as a reference Quote
375hp banshees Posted March 14, 2024 Report Posted March 14, 2024 Dont remember doing that b4 but... mark where the chain rides ( to make sure when rollers in place it'll be inline). & install it till it lines up. I'd think it'd bottom out? Is there an inner lip that'll stop it from going on to far ( and or can it even go on to far b4 hitting arm?) If you dont have a seal installer, use a large socket or see how tight it is, might be able to use roller, as an install tool...or a flat drift?? Quote
