06 banshee 2023 Posted September 4, 2023 Report Posted September 4, 2023 I have opened up the bottom end and put my shift shaft, drum, star and gears back in. The adjustment on the eccentric screw seems good, note that when I change gears, the adjustment gets a bit worse in some gears. What happens is when I spin the shafts and shift gears, every now and then, the gears get stuck. This means that I can’t spin the shafts anymore, but when I remove and put the shafts back in, it works. It looks like the dogs aren’t going into the gaps fully. I have rebuild these gears, replaced the 3rd gear and the 6th gear pinion IMG_0310.MOV Quote
locogato11283 Posted September 4, 2023 Report Posted September 4, 2023 You have to have a load on it for it to work properly. It's likely fine. Assemble the motor. Go ride. Quote
06 banshee 2023 Posted November 27, 2023 Author Report Posted November 27, 2023 On 9/4/2023 at 11:31 PM, locogato11283 said: You have to have a load on it for it to work properly. It's likely fine. Assemble the motor. Go ride. hey, I was talking to you on the thread about potentially splitting cases to fix this issue, hopefully the video above helps Quote
