I can reccomend rates, and ship direct, Banshee rear springs are $50, I've got them in 250 lb / in up to 500 lb / in rates in 25 lb / in increments.
When I get the $50 bucks can I just pm you with an order for one of these springs? The rear suspension on my shee is deinitely in need of adjustment!! THANKS!! :)
Travis
  • Replies 57
  • Created
  • Last Reply
Top Posters In This Topic
  • 3 weeks later...
Ok so if you have done this change in shock, you will notice about the 1 inch raise in ride height. The reason for this I think is that the stock preload setting is not right. I checked the stock setting and it was at 50% of what it should be. My sag was at 1 inch when it needs to be about 2 inches almost or 1.85 inches if you want to get exact. I think this is were the 1 inch rise comes from and I will adjust accordingly tomorrow when I go out and buy a spanner wrench.
I also noticed the increased ride height but when I am sitting on my shee ready to ride it doesn't sit to bad. The only mistake that I made was not checking the presets on my first ride, and I about jammed my wrists out of their sockets. Had to soften the ride up. The guy that I bought them from had the valves dialed all the way in. I also just got my shock back from TCS, and I must say that she rides like a cadilac now, before over big whoops, I could feel the shock bottoming out, but no problems now. Next is extended a a-rms.
This is probably going to sound stupid, but what is the bottom adjustment for on the 450 shocks??
1 full turn on my preload and my bike is at the same heigh as the works but I still need to go more. The preload on the stock settings is very soft.
  • 4 weeks later...
What's the latest news on those 450 shock conv.? Everyone still loving them? or Not? O....And did the rear 450 shock fit ok or not? Any grinding on the rear?
Thanks....
  • 4 months later...
Pablo, asi que te compraste los amortiguadores? preguntale a Javier como hizo para ponerlos, el los puso al toque, pero tuvo que modificarle anclaje en la parrilla creo
  • 2 weeks later...
]just wondering where you guys are finding all these shocks as here on the west coast of oz finding 2nd hand 450 shocks are rare as rocking horse teeth and new ones are close to $2000aud a set. any info would be helpful
Edited by randyt
