Anyone able to identify the noise?
My clutch seems to have swelled or something from sitting many years. It won't fully disengage even with adjustment.
Not sure that's my only problem though.. I also replaced the water pump bearing and seal when I had it open to adjust.
I'm 120psi on each side and leak down was good after putting new intake boots and seals.
https://youtu.be/SmTxHSgq8Y8
  • 3 weeks later...
On 4/26/2022 at 2:17 PM, guns4children said:
I had the same noise. I pulled my cover and found my idler gear had come loose. My washer and C clip went through my clutch gears and did some ugly things.
I also just had that happen to me. Completely replace idler gear and washer/clip. The bushings in the idler gears are known to go bad and it can leave a mess when they go bad
Yeah it was bad. My cushions were also gone. Guess 10 years is a little long to wait before you pull the cover lol.
