I have a 1996 Yamaha banshee with trouble running in the higher rpm’s. My setup is 34mm Keihin flat type carbs, pod filters, +4 timing advance, vforce 4 reeds, 21cc domes in cool head, trinity stage 4 pipes, and stock crank and top end.
The problem just started it seemed and when you rev it out it wants to fall on its face. Almost acts like it’s not getting enough fuel but the plugs look like a coffee type color. The main jets are 155’s. I also checked the stator and all the connections are in spec. Any advice helps on jetting or what my issue may be. And I messed with the needle and that has no affect on how it runs either so that’s not the issue. I also run 40:1 fuel mixture with 93 octane and castor 927 oil. Honda 80w in the tranny.
