First time posting. I bought a barn find 2003 Banshee. Carbs were off so I rebuilt them and did the tors delete. Unplugged everything not needed. I seem to have spark but doesn't even attempt to fire even with starting fluid or a little fuel in the cylinder.  I don't know much about it other than it has a cool head and T6 exhaust. Any help would be greatly appreciated. Otherwise I'll be looking for a banshee mechanic in Omaha Ne. Ha!
Choke crossover tube connected in the right spot? Make sure the slide move with the idle screws, zero them and as soon as they move go 3/4 to full turn. Pilots not plugged?
There’s very little to these shit boxes, it won’t be hard to figure out.
I didn't pull exhaust. Spark seems to be blue and not orange. So assuming that's OK.
Not if you put fuel to it & it didnt try .. unless it sheared the key & outa time or cant breathe
Sent from my SM-A505U using Tapatalk
Welp guys. Tried two things tonight. Re seated the ground on the rear and moved the pickup closer to the flywheel. A business cards worth. She fired right up!! Only thing now is left side seems a little cold coming out of the tailpipe but otherwise runs good.
So after it sat for less than a week I can't get it started again. It ran fine other than bogging a bit in second gear. Checked the pick up again and it hasn't moved. Re-seated the ground on the regulator again. Nothing. Any ideas?
@375hp banshees I reset the pickup gap. I had previously tested the resistance on all the things. Sounds like i need to get a new CDI. Appears they can cause intermittent issues? I shut the fuel off but didnt let the carbs run out of fuel. Is that a must?
