BansheeEaterKXF Posted December 20, 2003 Report Posted December 20, 2003 hey what hey hell is wrong with u all cant pull wheelie in 6th gear. my banshee will an so will both me tecates an my kx even will but only at about 60 or so.an if u guys have all that h.p. and cant get it to the ground then dont come to my track causes we power slide in fifth an wheelie out of it sometimes and if still dont belive me then come to the ice races this year in michigan an bring your check book Quote
rebelbanshee2 Posted December 20, 2003 Report Posted December 20, 2003 hey what hey hell is wrong with u all cant pull wheelie in 6th gear. my banshee will an so will both me tecates an my kx even will but only at about 60 or so.an if u guys have all that h.p. and cant get it to the ground then dont come to my track causes we power slide in fifth an wheelie out of it sometimes and if still dont belive me then come to the ice races this year in michigan an bring your check book picking it up in 6th and riding a wheelie at 75 are two very different things... Quote
Blue Duece Posted December 20, 2003 Report Posted December 20, 2003 hey what hey hell is wrong with u all cant pull wheelie in 6th gear. my banshee will an so will both me tecates an my kx even will but only at about 60 or so.an if u guys have all that h.p. and cant get it to the ground then dont come to my track causes we power slide in fifth an wheelie out of it sometimes and if still dont belive me then come to the ice races this year in michigan an bring your check book picking it up in 6th and riding a wheelie at 75 are two very different things... why thank you Rebel, very well stated, simple yet to the point....... Quote
frocashmoney24 Posted December 20, 2003 Report Posted December 20, 2003 yea, im with u 2, as soon as i see it, i will belive it but 75 is crazy with the air pushing against the bottom of the shee Quote
SCOTT PRESSLEY Posted December 20, 2003 Report Posted December 20, 2003 Raptor spindles on the shee will work.They are basically the same spindel as the 450 is running ,I measured them at dealer ship before starting the deal.They will make the shee 1inch wider on each side.I run heim joints on my a-arms and they bolted, up the tie rods bolted up, even the brake caliper did,but here is the but you need to use raptor or the 450 spindels.The shaft on the 450 and the raptor spindel is not as long as the shee and the shee hud does not have the offset in the back of it like the others.The brake rotors will work from the shee hub on the other hubs.My +2 tie rods would bolt up but had to adjust too far out so went with +3's. Before I installed the raptor spindels I polished the well you know out of them almost looks like chrome spindels.Choose these over ex's because less to change to use them and just couldn't get myself to run honda parts on the shee.But the ex's spindels are cheaper to buy new like 140.00 for the pair from dealer,Raptors are 174.00 each.Mine came off of e-bay.They look tuffffff on the front all shiny and everthing like that. I'll post some pics of them when I get a chance to take some. Quote
