SCOTT PRESSLEY
About SCOTT PRESSLEY
  • Birthday 10/10/1966
Contact Methods
  • Website URL
    http://
  • ICQ
    North carolina
  • Interests
    Goning fast,motocross and life
    red&black99 it anit stock thanks to the guy at the BHQ
SCOTT PRESSLEY's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. I need some help, got a freind that has a suzuki king quad,the promblem is that when he rides it for like an hour it will cut off and is very hard to get started a gain. Not sure what is going on with it any info would be great. Peace Scott
  2. You can get one from Wal-mart for not much that will be good enough to post pics of your stuff to sell.Just a thought
  3. Ok heres the thing,we got a local track owner that is thinking of tring to put on a big atv race.It will be basicaly ran like a national type race.You would have to qualify to be able to run in the main event.Here is the kicker it is an outlaw race which means it is not sanctioned by any organization it is just a race but,it has a total purse of 5,000 pay back.I talked to him tonight and he said that if it goes he only want 20 quads in the main in a class.So what I'm asking is any one interrested in a race like this? If you are you can post here or email the owner at [email protected] and let him know.If this thing does happen this year it will become an anual event.Thanks for your time in reading this post and any input would be welcomed.Just about forgot it is a MX race and would take place in Albemarel,NC Peace
  4. Moe- Riddle me this riddle me that,what is the end and the beginning all at the same time.
  5. I to have rode a 250r trike and loved it .I now ride a shee and have had it in the woods and trails but prefer it on a track.If you have had no problems with a250r three wheeler then your good to go with a shee.The only thing I would do to it to make it more for the woods and trails is drop a tooth on the front sprocket .Just get one hang on to it and have fun. AS for tires the razors are a good choice of tires I have run them and hole shots and they both have their place.The razors will last longer than the hole shots they are a harder composite rubber,but I think if I was just going to trail ride I would go with trail claws.They hook up a little better in the woods for me than the others did and also in the mud and they arent that costly
  6. Is your adjusters in the carb tops all the way in if not you can take some of the slack out there.Also the cable should have some adjustment infront of the bend where it goes into the tops to.Just a thought hope it helps.
  7. To answer your question SyNtAxx no.The 450 should not out run you with your set up.I have basicaly the same set up and pulled the hole shot over a 450 last week at the track.The 450 was piped and jetted with an after market airbox on it.
  8. What Tats said the -2 is the way to go.Adjust it all the way in and it's -2 adjust it out and it's almost a -1.All you need to do is to have the right length chain to run what ever lenght arm you want it to be.The -2 does hook in the corners and makes it corner like mad.Get use to it and I think you'll like it alot.
  9. I got the heims.They are ok,they require more mantianance than a ball joint.I myself have had one lower heim come apart on me on the track but the nut backed off the lower side.As for taking care of them you need to spray some wd40 or something like it on them after a wash to keep them from squeeking .The ball joint is sealed for the most part you just need to grease them if they have a fitting.I have seen lsr ball joint brake on the track but they were on raptors and a blaster.The shaft broke at the arm.It really just matters what you want and trust.
  10. Yea I got one about that size in my backyard top of 4th will do it but 5th wo will do it better
  11. They have been sold
  12. JB weld it will hold it in place if you can get it there.just put a very little bit on it you wouldn't want this stuff squirting out around it sets up just like steel.
  13. Mighty vac.Tried to bleed my fronts with everything,after I got very tired of not making any head way I went and got one.it came from Auto Zone only cost 25.00 and made it very easy to do just hook it up pull a vacume and make sure your res. don't get empty and your set.The instructions that came with it was very helpful.Also you may need to put some white plumers tape on your bleeders so they want leak air around them while your bleeding your brakes.also has a container on it to catch the fluid so you can keep using what comes out.
  14. Or an air leak,what intake you running.If it is one of the ones with the boost bottle that has rubber gromlets then one of them might be leaking some air.
  15. Me thinks it make the shee look like the new Blasters,and why would a person want to that.
