kawa110 Posted November 14, 2020 Report Posted November 14, 2020 Got a shee with Duncan mid range motor. seller told me to run 50/50 race gas and 91. bike set up for glamis. called Duncan and I was told to run 110 or higher, not mix. I asked about going +4 on timing and was told with ther port job that it’s not necessary. 1. should I go +4? Got a adjustable plate and a lightened flywheel(not installed yet) 2. race gas or mix? 3. Duncan’s “instructions” for the mid range motor is too run b9es plugs, I have always ran b8es. Why b9? Quote
375hp banshees Posted December 3, 2020 Report Posted December 3, 2020 ^^ ^^ Ask him how dat werked out on da boat... I'd do what duncan said for all 3...safer to start that way , any way. do compression check and or c.c. it & inspect plugs after . Quote
kawa110 Posted December 5, 2020 Author Report Posted December 5, 2020 3 hours ago, DDQ said: Congrats on that motor! How did you get ahold of it? For those who did not know, that is the motor Doug Eichner raced and WON many pro and pro-am MX races with in the 90's with ZERO DNFs. It is also the motor still being run by most of the banshees competing in the Point de Vaux. https://dirtwheelsmag.com/hot-rod-banshees-mx-tt-quads/ Hp2000 im very happy with it!!! Quote
375hp banshees Posted December 5, 2020 Report Posted December 5, 2020 Apparently not, you're asking The dumb asses on here , what to do.... over what Duncan saidSent from my SM-A505U using Tapatalk 1 Quote
Deets Posted December 5, 2020 Report Posted December 5, 2020 I’d be curious what the compression is. Quote
375hp banshees Posted December 5, 2020 Report Posted December 5, 2020 OopsSent from my SM-A505U using Tapatalk Quote
