we have the wifes banshee running 7.74 - 7.82 1/8ths is that good?  Its on a heavy drag frame with a +8 swing arm mainly so I don't have to worry about it standing up with her . Motor is stock crank stock cylinders 80 over is ported but not drag ported say a maybe a dune port at best .  Boyesen super stock reeds  40 thousandths off stock head 34 or 35mm air strikers no filters . Timing plate compression is 140 17 front 38 rear Hinson 8 plate basket no lock up an trinity  small bore out frame pipes .  So for the mods an being pretty heavy 7.74 83 mph 1/8th (best) 7.86 82 mph 1/8th (worst ) is that pretty good ? Is on pump gas 93 octane with 18x8x10 rear . My question is that good times for what we have or should I expect more an yes jetting seen to be good we are 2500-3000 elevation  . I just wanna know is it good been around built  6.50s 6.00s bikes alot but not any thing like ours to judge against.  Thanks in advance !
I'd say that's very good based on the mods listed. My wife ran 1/4 mile up until 2018 on a stock stroke motor so if you want to pm me we can talk specifics.
