Fordfamily63
    Tn
  • Interests
    Racing an teaching kids to go fast
    87 j arm drag bike (needs bottom end) 97 motor on drag frame( wifes)
Recent Profile Visitors
Fordfamily63's Achievements
  1. An skeeter had a stock crank 80 over 170 on pump gas . 1/8th mile running 7.60s so I have a problem with fuel an jets not motor building.
  2. No on voitos an in Tennessee it was still cold an had jets right so I thought now it’s 100 over 1/8th start an stop that’s it what is max on compression I can go I raised base gasket up 4 thousandths have not set cylinders on yet
  3. 4mil short rod 513 66mm pistons stock cylinders 4mil 19cc dimes squish is 44 thousandths compression was 205 each cylinder . Now the fun Distorted piston after plug center came out BR7ES .30 gap . 35mm air strikers 160 main 48 pilots center on needle . C16 fuel 40-1 Elevation between 2000ft an 3000ft different 1/8 miles . So I need help new piston an dome on the way . An ported to 196 on a deg wheel maybe 10 passes .
  4. Looking for some out frame drag pipes small bore . I like the trinity’s we was running. Will look at any small bore chrome in decent shape .
  5. Looking for some out frame drag pipes small bore . I like the trinity’s we was running. Will look at any small bore chrome in decent shape .
  6. Ok thanks
  7. Ok Tedder new to the site so takes a few to figure it out .
  8. we have the wifes banshee running 7.74 - 7.82 1/8ths is that good? Its on a heavy drag frame with a +8 swing arm mainly so I don't have to worry about it standing up with her . Motor is stock crank stock cylinders 80 over is ported but not drag ported say a maybe a dune port at best . Boyesen super stock reeds 40 thousandths off stock head 34 or 35mm air strikers no filters . Timing plate compression is 140 17 front 38 rear Hinson 8 plate basket no lock up an trinity small bore out frame pipes . So for the mods an being pretty heavy 7.74 83 mph 1/8th (best) 7.86 82 mph 1/8th (worst ) is that pretty good ? Is on pump gas 93 octane with 18x8x10 rear . My question is that good times for what we have or should I expect more an yes jetting seen to be good we are 2500-3000 elevation . I just wanna know is it good been around built 6.50s 6.00s bikes alot but not any thing like ours to judge against. Thanks in advance !
