It was several passes. Three I think. I usually run 110 octane, straight. Yes I know it's expensive, but I love the smell B) . Elevation is 700ft above. It is just a mild port job. I was going to get more porting when I installed the new carbs, but time does not permit. The bike was tuned for our upcoming trip to Yuma/Glamis. Wound up having to lean out the carbs. I now have 142 mains in.
I recently put on one of those K&N filter lids for my airbox with no outwear on the lid. The friend that did my porting said not to run the outerwear. Too restrictive.
When I got it dyno'd, they guy told me that the LID was restrictive and I should run just and outerwear on the PRIMARY filter. What do you all think?
He told me this HP was about average for a 350 with this setup, without stepping up stroke and bore.
I said "stroke" :lol:
Banshee's RULE
dyno charts mean nothing all a dyno is this its gives you a base line so you can tell how much hp you gained by adding a new part and you have to test the same day so many factors like temp humidty change the numbers also some dynos will give you higher numbers then others some will give you alot lower numbers there just never acurate
i duno what kinda porting you have but 60 hp for a ported bike isn't all that bad dyno could have been a little low that day depends on what style porting you whent with and who ported it
outerwear is in no way more restrictive than the airbox lid! Now way at all!
142 mains ! I didnt know they made them that small, You sure something isn't wrong? After I got porting I had to go up to 370's in my stock carbs!
142?!?! How does your engine get any fuel?
Leadfoot,
A local guy from one of the bike shops did my porting, he works hand in hand with the shop that does the dyno. It was tuned for the K&N filter lid installed, so I had to go from 148 mains to 142.
Do you mean individual filters for each carb? No airbox?
Peace
well that explains the jet size thing :)
Your engine will flow more air with clamp on and no airbox, But it will also flow more air with the lid off and a precharger (outerwear)(since you already have the single clamp on). The little less airflow the prechargers gives you is, IMO, better than clogging up your K&N with dust and sand at glamis, and it will still flow more air than running it with the lid on. Definately run the prechargers and no lid for glamis.
When I put my lid on my Banshee boggs horrible and I can't even hit the powerband, because Im jetted for no lid, I think its something like 3-4 jet sizes (Mikuni) difference. I dunno how much HP gain it will give you but it might just bring you up to mid 60's after you re-jet.
