I recently got my banshee rebuilt and started fat on the jetting then worked my way down. If I move up 1 size richer it runs like shit till half throttle. It runs ok right now it hesitate a little at quarter throttle but I had to raise my needle clip up to the second mark to get it to run that good I do not want to go all the way up on the clip you think it would be okay to go a little leanerdd6813fc79d1d7d8704a4014fe406931.jpg5861ee552e755f39f7c6445f47c86af4.jpge47f1c361f2e3d39656def16bcf0d0df.jpg
Sent from my 5059S using Tapatalk
Edited by Tobynblevins
Miss spelling
5 hours ago, JerzOutlaw350 said:
It wouldn’t hurt to try it. But to be safe it’s always good to be a little on the rich side.
I did did not help my bottom end power any also tried a number 45 pilot jets still no power till Quarter throttle
Your safe. The problem your describing is pilot jet. Raise your needles first (more air) and see if that makes a difference. If it get s worse or better change your pilot accordingly
1 minute ago, gusto said:
Are you running stock carbs? Is it ported? Is it piped? Aftermarket reeds?
28 pwks they are not knock offs carbs. dmc pipes. jetting for all dmc pipes are the same but Not sure what dmc pipes they are ..everything else is stock No porting nothing
5 minutes ago, gusto said:
Move your needle clip to determine your pilot. You’ll get it
What do you mean? Like if I’m lean on my clip that means I’m lean on my pilot.. and ty for the help btw
Example, if you move your needle to create a richer position and the bog gets worse that means you’ll need less gas. So you will need a smaller pilot jet.
And get your air screws to work perfectly from a half a turn out to 1.5-2 turns out from being fully seated.
