Everything posted by Tobynblevins
Theses plugs look rich still?
Tobynblevins replied to Tobynblevins's topic in Banshee Repairs and Mods
What do you mean? Like if I’m lean on my clip that means I’m lean on my pilot.. and ty for the help btw -
Stripped footpeg insert in frame Help!
Tobynblevins replied to Green95LX's topic in Banshee Repairs and Mods
I had this problem.. I Re-threaded -
28 pwks they are not knock offs carbs. dmc pipes. jetting for all dmc pipes are the same but Not sure what dmc pipes they are ..everything else is stock No porting nothing -
Is it safe to be on the first clip of the needles -
I did did not help my bottom end power any also tried a number 45 pilot jets still no power till Quarter throttle -
Anyone ? -
I recently got my banshee rebuilt and started fat on the jetting then worked my way down. If I move up 1 size richer it runs like shit till half throttle. It runs ok right now it hesitate a little at quarter throttle but I had to raise my needle clip up to the second mark to get it to run that good I do not want to go all the way up on the clip you think it would be okay to go a little leaner Sent from my 5059S using Tapatalk
Im running dmc pipes my banshee is all stock except my carbs are pwk stock air box 600ft above sea level .. do I go up in jet size from the 26 stock carb with the 28 pwk or down and where should I start on jet size I checked the jetting forms but no one is really Running dmc pipes and if they are it's with 26 mm carb. I know how to jet just not where to start with dmc pipes using 28mm pwk.
Stud broke off deep in case
Thanks for the info the guy that works at the Machine Shop said that he has a drill bit that will drill away the whole stud and if it messes up the threads he will put a helicoil in it. I have a extra set of cases but not trying to use them on this banshee -
The guy looked at his shop Said he can get It out then put a Helicoil in it if it messes the threads up. But he said he had a drill bit that will drill it out. Some people say helicoils dont work very well but I have them in my yz250 and never had a problem. -
I baught a stud remover tool and was trying to remove the stripped stud out of my banshee case that bolts my cylinders down and the stud broke off deep in cylinder its seized up pretty bad so I called a machine in town and they're not sure if they will be able to drill it out because it's aluminum how would I be able to get this out if my local machine shop can't do it.
I'm looking for a case stud and cant find one. My case dowel got smashed that lines up the Cylinder and I cant get it removed so I have to remove the whole stud. If Somone can post me a link to one I will appreciate it or if you know the size of the stud I can buy 1 at tractor supply. If your standing in front of banshee looking at exhaust it's the shorter stud closest to the exhaust on the left cylinder right hand side of left cylinder towards the front
Weird tinging sound right side
Tobynblevins replied to hoppedupandcutdown's topic in Jetting & Exhaust Forum
I'm not from wv?? But I have seen some inbred mother fuckers with better jokes and definitely way smarter then you...your jokes are original as fuck.Its funny your intelligence is so low that you get mad and start calling names like a child just because your wrong about something that you disagree with on my post.. I mean I can tell your not completely retarded because your typing and you probably came in first place during the special Olympics and got some trophies for it but arguing with you is like winning the special Olympics I may have won but did I really win any thing?? Sent from my SM-J337VPP using Tapatalk -
Is this cylinder look ok it's only got 2 hrs on it
Wow that joke was so creative.you come up that your self??? I dont think I ever hurd it before[emoji23][emoji23] if I had a sister and I was fucking her it still not be as nasty as any bitch you ever fucked in your entire life and still wouldn't be ok even in wv Sent from my SM-J337VPP using Tapatalk -
I'm about a 2 min walk from the Hatfield and McCoy trails. Sent from my SM-J337VPP using Tapatalk -
Next time you on them Hatfield and McCoy trails pay me a visit we can go riding lmao . I moved from Ohio to Williamson wv for the trails. Sent from my SM-J337VPP using Tapatalk -
Your saying they dont make remanufactured cylinders when they do[emoji23][emoji23][emoji23][emoji23] So you can keep huffing spray paint before typing sentences saying what you want to say. Yall are fucking idiots Sent from my SM-J337VPP using Tapatalk -
Hey skeeter Peter stfu your jokes are not even funny.. you call me dumb because I'm talking about remanufactured cylinders because they dont exist[emoji23][emoji23] but 90% of cylinders on Ebay say remanufactured [emoji2369] proof is right there.. you must be one of Jerry's kids Sent from my SM-J337VPP using Tapatalk -
Wrong. Sent from my SM-J337VPP using Tapatalk -
Ok so yall started trash talking because I said my cylinders are remanufactured lol[emoji23][emoji23][emoji23][emoji23][emoji23] and both my cylinders say they are remanufactured after taking a closer look at the listing on the cylinders I just got from a totally different seller[emoji1787][emoji1787] one just said it in description other did not. So yall are fucking idiots and Obviously don't know what your talking about.. Sent from my SM-J337VPP using Tapatalk -
Stop talking. Sent from my SM-J337VPP using Tapatalk -
Just returning the favor Sent from my SM-J337VPP using Tapatalk -
Trash oem cylinders. And I'm sorry those pistons are not wiseco they was vitos.. I realized that when i opened my box of wiseco pistons and still have 2 in the box. No one has really tried to help only troll. I'm rebuilding my banshee as we speak. I did complete rebuild and putting everything back on the engine right now. I would ask what size pistons are #4 and if I should re jett but I may get trash talked.i will admit I don't know the exact mechanics of a engine I just know I can take them apart and put the pieces back where they belong when I'm finished because I have pretty decent memory on certain things Sent from my SM-J337VPP using Tapatalk
